Thread repair problems
PostPosted: 22:47 - 11 May 2009    Post subject: Thread repair problems Reply with quote
Hello,
I bought some helicoil style thread repair kits off of ebay for my RD350. The exhaust stud holes in the barrels were stripped, so I helicoiled the only one that wasn't already done.
Slight issue though, when I screw in the stud (or bolt) into the freshly repaired thread, it strips the thread from the bolt!
I'm certain the pitch and diameter are correct (M8 x 1.0mm) so I'm guessing something went awry with my fitting of the thread repair thing. Anyone know if they are easy to remove and start again? At the moment the bolt I've put in holds so its not a total disaster, but its not quite as good as I had hoped.
Any thoughts?
Blue_SV650S
PostPosted: 23:17 - 11 May 2009    Post subject: Reply with quote
Dude, don't hold me to this, but I thought the pitch was 1.25??? .. perhaps you have a fine thread tap/helicoil Thinking
I could be taking sh1te mind you ... but I suggest you google to check for sure ..
sickpup
Old Timer
PostPosted: 00:01 - 12 May 2009    Post subject: Reply with quote
It's M8x1.25 thread. I sell loads of the studs and brass nuts and they are pretty much always this thread pitch when going into Aluminium. Did you not check the tap in the kit against a stud?
PostPosted: 07:45 - 12 May 2009    Post subject: Reply with quote
Maybe I need a 1.25mm pitch stud then. As I said I'm not using a stud at the moment because I stripped the last one I had. I'll check the kit but I'm fairly sure it was the correct pitch and stuff. Maybe I'm wrong about it being M8 x 1.0mm. The bolt I used is definately M8 x 1.0mm. If it is 1.25mm that could explain why it is being stripped!
PostPosted: 08:58 - 12 May 2009    Post subject: Reply with quote
Embarassed Embarassed Embarassed
I used a M8 x 1.0mm thread repair kit on an M8 x 1.25mm thread. Embarassed Embarassed Embarassed
Stoopid. That'll teach me.
Anyone know where I can get an M8 x 1.0mm bolt? Smile
spitfire123
PostPosted: 16:30 - 12 May 2009    Post subject: Reply with quote
ebay have a few nut&bolt sellers mate Smile
give them a go Thumbs Up
You won't be able to eat my dust......As it'll settle before you get there.
The last post was made 17 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 51.28 Kb
