Sanding down stairs
mrtEE
PostPosted: 12:49 - 14 May 2009    Post subject: Sanding down stairs Reply with quote
I have wooden staircases in my house (2 of them as its 3 storey) but someone has painted them white, including the steps.
This is not practical as the paint chips and it shows up the dirt very well. So i want to sand them down to wood, and think it will look better. Will just be sanding the steps down and leaving the banisters etc. white.
What is the easiest/quickest/best/cheapest way of sanding them back to the wood? Don't fancy doing it with a sheet of sandpaper as it would be back breaking and take weeks.
Mrs Kickstart
PostPosted: 13:10 - 14 May 2009    Post subject: Reply with quote
Probably best to hire something like This a normal b&q sander would probably take ages
Regards
C
Help fight the safety camera partnerships Twisted Evil -- www.pepipoo.com
Feasty
PostPosted: 13:21 - 14 May 2009    Post subject: Reply with quote
Just cut up a few sheets of sandpaper roughly a foot square, attach elastic to the back of them. Then leave half of them at the bottom of the stairs and half at the top and ensure everyone who walks up and down those stairs puts the sandpapersheets over their feet first, then takes them off at the other end. That way there will always be sheets available at the top and bottom of the flights of stairs and within a month you should have well sanded stairs!! Laughing
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
mrtEE
PostPosted: 13:25 - 14 May 2009    Post subject: Reply with quote
Regards
C
I was thinking maybe to hire an industrial sander, but would it be tricky due to the size of the steps and number of corners?
Kwaks
I'm not a fast rider
What sort of paint is it?
Would a heat gun not be more practical?
www.cliqueycuntsmcc.co.uk
mrtEE
PostPosted: 13:29 - 14 May 2009    Post subject: Reply with quote
Not entirely sure but I suspect it is just emulsion paint. Would some kind of paint stripper be another option?
map
Mr Calendar
PostPosted: 16:12 - 14 May 2009    Post subject: Reply with quote
If on wood likely to be gloss paint.
I'd go with paint stripper (Nitromors), follow the instructions.
Do every other tread & riser first, clean it up, then repeat on the remaining treads/riser (please don't ask why, think about it)
After removing it use wire wool to remove any other paint from the grain and in corners.
Like sandpaper you can get different grades or wire wool, work from high to low numbers.
The wire wool will allow you to get into corners more.
After that sanding is an option, the floor edging type one mentioned above plus you can get detailed sanders (shaped like an clothes iron).
Should be able to rent from you local HSS or similar tool hire place.
Other than that google is your friend.
A quick search gave these results
Remember you'll need to protect the wood so look into stains or oils. You don't want stairs slippy so don't varnish them eh! Confused Wink
HTH Thumbs Up
Skudd
PostPosted: 17:06 - 14 May 2009    Post subject: Reply with quote
Carpet.
Kwaks
PostPosted: 21:38 - 14 May 2009    Post subject: Reply with quote
Skudd wrote:
Carpet.
Thats for after he has gone to all the effort..........and fecked it up Wink
Tonka
PostPosted: 22:53 - 14 May 2009    Post subject: Reply with quote
Thinking Gloss paint on the stairs - bet you get down stairs nice and quick!!
You can hire belt sanders and as long as you go with the grain you should have quite a good result, but it will be blo00dy messy and take ages! Even the ones that attach to vacuum cleaners make more dust than you can imagine Rolling Eyes You'll get through heaps of sand paper too and the ones they supply are quite pricey.
Heat guns are good and quickish, but I'm not very good with them and always manage to burn a bit by leaving it on too long getting all impatient! Tends to ruin the 'naked' finish if you have a feck off big burned bit, which will always be somewhere really obvious 'cos that's the way it happens!! Embarassed
Flip
PostPosted: 23:50 - 14 May 2009    Post subject: Reply with quote
I thought 'down stairs' was you being poilte.
The last post was made 17 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 69.57 Kb
