| mrtEE |
 mrtEE World Chat Champion
| Mrs Kickstart |
 Mrs Kickstart Brolly Dolly
 Posted: 13:10 - 14 May 2009 Post subject: |
Probably best to hire something like This a normal b&q sander would probably take ages
Regards
C ____________________ Help fight the safety camera partnerships -- www.pepipoo.com |
| Feasty |
 Feasty World Chat Champion
 Posted: 13:21 - 14 May 2009 Post subject: |
Just cut up a few sheets of sandpaper roughly a foot square, attach elastic to the back of them. Then leave half of them at the bottom of the stairs and half at the top and ensure everyone who walks up and down those stairs puts the sandpapersheets over their feet first, then takes them off at the other end. That way there will always be sheets available at the top and bottom of the flights of stairs and within a month you should have well sanded stairs!!  ____________________ Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed). |
| mrtEE |
 Posted: 13:25 - 14 May 2009 Post subject: |
| Mrs Kickstart wrote: | Hi
Regards
C |
I was thinking maybe to hire an industrial sander, but would it be tricky due to the size of the steps and number of corners? |
| Kwaks |
 Kwaks I'm not a fast rider
What sort of paint is it?
Would a heat gun not be more practical? ____________________ Fallen Angel "Nae sniffing my seat now!!!!! "
www.cliqueycuntsmcc.co.uk
I AM NOT A FAST RIDER!!!!!!!!! |
| mrtEE |
| map |
 map Mr Calendar
 Posted: 16:12 - 14 May 2009 Post subject: |
If on wood likely to be gloss paint.
I'd go with paint stripper (Nitromors), follow the instructions.
Do every other tread & riser first, clean it up, then repeat on the remaining treads/riser (please don't ask why, think about it)
After removing it use wire wool to remove any other paint from the grain and in corners.
Like sandpaper you can get different grades or wire wool, work from high to low numbers.
The wire wool will allow you to get into corners more.
After that sanding is an option, the floor edging type one mentioned above plus you can get detailed sanders (shaped like an clothes iron).
Should be able to rent from you local HSS or similar tool hire place.
Other than that google is your friend.
A quick search gave these results
Remember you'll need to protect the wood so look into stains or oils. You don't want stairs slippy so don't varnish them eh!
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Skudd |
 Skudd Super Spammer
| Kwaks |
 Posted: 21:38 - 14 May 2009 Post subject: |
Thats for after he has gone to all the effort..........and fecked it up  ____________________ Fallen Angel "Nae sniffing my seat now!!!!! "
| Tonka |
 Tonka World Chat Champion
 Posted: 22:53 - 14 May 2009 Post subject: |
Gloss paint on the stairs - bet you get down stairs nice and quick!!
You can hire belt sanders and as long as you go with the grain you should have quite a good result, but it will be blo00dy messy and take ages! Even the ones that attach to vacuum cleaners make more dust than you can imagine You'll get through heaps of sand paper too and the ones they supply are quite pricey.
Heat guns are good and quickish, but I'm not very good with them and always manage to burn a bit by leaving it on too long getting all impatient! Tends to ruin the 'naked' finish if you have a feck off big burned bit, which will always be somewhere really obvious 'cos that's the way it happens!!  ____________________ 'The core of a man's spirit comes from new experiences'
Suzuki SV650S (Clean); Yamaha XT250 Serow (Dirty) |
| Flip |
 Flip Super Spammer
The last post was made 17 years, 136 days ago. Instead of replying here, would creating a new thread be more useful? |
