| DevilDex666 |
 DevilDex666 Nova Slayer
| spitfire123 |
 spitfire123 Could Be A Chat Bot
| DevilDex666 |
| stirlinggaz |
| joan33987 |
 joan33987 Renault 5 Driver
 Posted: 18:40 - 12 May 2009 Post subject: |
Was it stolen while you're at home? The disc lock alarm was killed before it can go off?
So the starter is spinning the engine, but the engine won't fire up? or You only heard the starter motor go "buzz" and the engine still won't turn at all?
did you ground the spark plug while testing for spark?
It will not spark if you just hold the spark plug with the spark plug cap in the air.
How to check ignition coil working:
(remember turn off ignition switch before messing with ignition coil)
Connect the spark plug wire to ignition coil and one end to the multimeter in voltage setting(dc 500v), it don't matter you connect to the + or - lead of the multimeter , connect the other lead from the multimeter to the battery's minus or frame.
Start the engine, when engine cranking, there should be reading on multimeter. anything other than 0 is a reading.
might they have fucked up your carburettor?
where are you based? MIGHT be able to come have a look if it's near ____________________ current toys: Skygo SG125-J 125cc stolen again 1992 Kawasaki GPZ500S (crashed damaged) 1996 Renault Clio 1.2 2005 CG125 project |
| DevilDex666 |
| joan33987 |
| DevilDex666 |
| DevilDex666 |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 20:17 - 12 May 2009 Post subject: |
try this:
your CDI you have the HT lead with the spark plug attached, one wire attached with a blade connector, and one attached with an eyelet through a screw.
remove the eyelet screw wire, and see if it starts.
if it does, be careful as your killswitch wont work. should get you on the road for the time being till you can sort it properly. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| TUG |
 TUG World Chat Champion
| DevilDex666 |
 Posted: 01:11 - 13 May 2009 Post subject: |
| XlonewolfX wrote: | Sounds odd indeed, so they just ripped the ignition switch off? the block that is? hmm, did they take your panels off and dabble with your relays and wires? |
Basically I think they broke into the rear of the bike first and took out the Cagiva toolkit. They used the allen key in there to undo the screws around the ignition bracket and popped it off. they put the bracket in the back of the bike which was thoughtful of them but think they had trouble actually pulling out the ignition itself due to the steering lock/ top yoke. this is where they must have used the crowbar to prise it loose. I think they then severed the ignition wiring using a lighter as there are burn marks around the wire sheathing. I guess they saw the steering dampner as some form of threat as this too was prised off, snapping it at its securing points. You can actually see the dents in the fuel tank where it was used.
The panels were still in place but the fuel tank was twisted at the hinges which I think severed the fuel sensor wiring. Maybe they nearly dropped the bike and tried lifting it back up by the tank?? The ignition bracket also holds the tank in place via a thick elastic/ rubber catch and as this was removed the tank would just lift from the bike on its hinges. I think they dropped it on its side as one of the mirror support brackets was partly damaged also.
I do not think they messed with the relays as they all seemed in place and no loose connections. Although one of the two 15 amp fuses was burnt out which sits near the starter relay.
I think they planned to come back for the bike as it was concealed behind a bin shed with a wooden board up the front of it so it could not be seen. luckily, the wind must have blown the board down as it had slid down the front of the bike for me to see it. The next day I looked around the area and found parts scattered about hidden in bushes etc such as my reg plate, steering dampner, parts of the ignition housing, cap from the lock on the fuel tank. They kindly left the Cagiva tool kit in the back of the bike minus spanners and allen keys of course. ____________________ "But I being poor, have only my dreams, I spread my dreams under your feet, tread softly because you tread on my dreams." ("He Wishes for the Cloths of Heaven" - W.B. Yeats) |
| DevilDex666 |
| DevilDex666 |
| MaybeGuy |
 Posted: 23:11 - 14 May 2009 Post subject: |
just to clarify, its only the 1 wire you're removing, yes? have you checked for a spark yet? take the sparkplug out and attach it to the HT lead, then see if it sparks when the engine turns over. make sure the end of the plug is touching part of the engine to earth it. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| DevilDex666 |
| DevilDex666 |
| Ingah |
 Ingah World Chat Champion
| DevilDex666 |
| DevilDex666 |
| DevilDex666 |
| MaybeGuy |
 Posted: 23:47 - 14 May 2009 Post subject: |
not sure if the evo ignition is the same as a MK2, but heres how to hotwire it if you want. then do the CDI wire like i suggested before.
https://img233.imageshack.us/img233/9558/06092008279gk1.jpg ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| DevilDex666 |
 Posted: 23:53 - 14 May 2009 Post subject: |
hmmm i may just give that a go but have to look to see if i still have the original wires from the old ignition and plug them back in. dont fancy cutting the wiring on the replacement ignition. looks as though i have something to do tomorrow
where did you get the pic from? its not one you did earlier i hope ha ____________________ "But I being poor, have only my dreams, I spread my dreams under your feet, tread softly because you tread on my dreams." ("He Wishes for the Cloths of Heaven" - W.B. Yeats) |
| MaybeGuy |
 Posted: 00:01 - 15 May 2009 Post subject: |
its my MK2 mito before i RD350'd it, and bought a new ignition. came without a key ysee. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| DevilDex666 |
The last post was made 17 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
