How long does it take to run a car battery down?
cal91
PostPosted: 00:49 - 19 May 2009    Post subject: How long does it take to run a car battery down? Reply with quote
Theres a party going on... we need music.
So how long would it be before my radio fvcked over my battery?
I'm not bothered if the car wont start after, we can just jump it Smile
We are the Patriots! Love your country.
Flip
PostPosted: 01:30 - 19 May 2009    Post subject: Reply with quote
You're having a party in your car? Laughing I imagine a good few hours before the battery went flat.
cal91
PostPosted: 01:33 - 19 May 2009    Post subject: Reply with quote
No it's in a field Laughing
But the field is quite a bit away from houses so there's no electric.
killa
Won't Shut Up
PostPosted: 08:08 - 19 May 2009    Post subject: Reply with quote
Depends how loud and what system you got.
I'd say 6-7 hours tops.
Blue_SV650S
PostPosted: 08:12 - 19 May 2009    Post subject: Reply with quote
It depends on your ICE system (and the car/battery size), some systems are pretty thirsty for power if you have lots of subs etc ... but if it is all standard then it'll last longer than you can keep drinkin'/dancin' Very Happy
Kwaks
I'm not a fast rider
PostPosted: 08:14 - 19 May 2009    Post subject: Reply with quote
Also depends on the battery, how well it holds its charge, whether he will start the engine periodically to recharge it, the ambient temperature, if interior car lights are also on, whether the headlights are on etc etc etc
Might as well ask about the string Wink
www.cliqueycuntsmcc.co.uk
Matthie
PostPosted: 11:00 - 19 May 2009    Post subject: Reply with quote
Pretty sure this is pointless, don't you have to be moving for the battery to be charging?
truslack
PostPosted: 12:06 - 19 May 2009    Post subject: Reply with quote
No, but I doubt much power would be generated at idle.
chrisw
PostPosted: 12:43 - 19 May 2009    Post subject: Reply with quote
If your alt. can't charge the battery at idle with nothing running (headlights etc.) then its fecked.
Also the power required to start the engine would require running the engine for some time to replenish.
As to how long the battery lasts, as said, there are far to many variables to make an accurate guess.
Faldo
PostPosted: 13:31 - 19 May 2009    Post subject: Reply with quote
Most cars these days have a timeout on the radio when the ignition is switched to "Acc", so you'll be resetting it every 20-30 mins anyway. Unless you were planning on leaving the ignition on? In which case you will probably fry your coil(s) and end up with a dead car in the middle of a field.
Get yourself a rasta blaster with huge batteries.
Current: ZZR1400
Stalk
PostPosted: 13:38 - 19 May 2009    Post subject: Reply with quote
Hello, from a few years back. Volvo 940 Turbo. Big battery. Pioneer headunit, Sony crossover. 100w amp front, 240w amp rear, 300w amp driving twin coil 12" sub. 20 min at loud was all the battery would last, and the battery was not old. Park on a hill.
Hope that helps.
Stalk
Cigaro
PostPosted: 12:51 - 20 May 2009    Post subject: Reply with quote
Had my Polo's stereo going for 6 hours before and the car still started fine afterwards. That is with standard speakers, JVC MP3 headunit, and Halfords 50w underseat sub. Newish battery too. Your mileage may vary.
The last post was made 17 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 71.92 Kb
