occasionaly hard to start?
salty21
PostPosted: 16:31 - 26 May 2009    Post subject: occasionaly hard to start? Reply with quote
just a quicky, 9 times out of 10 my bike starts straight away but then out of the blue it will just crank over with the occasional burble for about 20 seconds before starting, this usually happens when setting off from work in the evening and always starts fine in a morning no matter how cold/damp it is.
the bikes done just over 20.000 miles and as far as i know is still on the origional cam chain tensioner, could this be the bike telling me it wants a new one or could it be something else?
oh and i have just done the valve clearances which were all within tolerances, number 4 ex valve's were a touch on the tight side but still within spec.
muffy
PostPosted: 16:56 - 26 May 2009    Post subject: Reply with quote
what bike is it m8 and is electric or kick start you are having trouble with
salty21
PostPosted: 17:03 - 26 May 2009    Post subject: Reply with quote
cbr600rr3 electric start
iooi
PostPosted: 18:18 - 26 May 2009    Post subject: Reply with quote
Sounds like a normal bike to me...
I would start to worry, when it does not want to start more than when it does.
Could be some muppet is playing with the throttle while you are working and pumping some petrol into the cylinder.
PostPosted: 18:39 - 26 May 2009    Post subject: Reply with quote
Shouldn't make a difference. With the ignition off there's no power to the injectors.
Only thing that may help could be an oil change, but that's a bit of a long shot. I wouldn't worry too much, my car does it from time to time where it takes longer than normal to catch.
salty21
PostPosted: 19:42 - 26 May 2009    Post subject: Reply with quote
did the oil change on saturday when i checked valves, made no difference apart from the usual smooth as silk feel you get with new oil Drooling , im only concerned as it has gradually occured over the last 5000 miles or so and used to start like clockwork before that. maybe its just getting on a bit is all Rolling Eyes
yen_powell
PostPosted: 20:48 - 26 May 2009    Post subject: Reply with quote
Have you replaced or cleaned the sparkplugs lately or are they still the original from new? 20,000 miles isn't even run in properly let alone past it on one of those.
XT1200Z and a DR350 in bits
salty21
PostPosted: 23:03 - 26 May 2009    Post subject: Reply with quote
yep new plugs recently, cleaned and gapped on saturday with all the other bits n bobs.
how many miles should i expect from her then?, i always though they were only good for 40-50,000 before major internals needed replacing
yen_powell
PostPosted: 23:24 - 26 May 2009    Post subject: Reply with quote
I'd expect at least a 100k if looked after and the oil changed regularly.
salty21
PostPosted: 23:36 - 26 May 2009    Post subject: Reply with quote
lol no worrys with the oil changes, it gets done every 1000 miles, OTT i know but it just feels too nice when its fresh Laughing
TUG
PostPosted: 23:50 - 26 May 2009    Post subject: Reply with quote
Gapped? they come gapped already...
Have you cleaned your air filter recently?
Haz ER-5, innit!
salty21
PostPosted: 16:51 - 27 May 2009    Post subject: Reply with quote
got new plugs and air filter about 5 months ago, i just checked them to make sure the gap was still right as i have done around 5000 miles since then.
didnt want to start again today, fine in the morning then a bugger after work, i noticed that if i nip to the shop at dinner on it then its fine at home time and if i dont it's not, but like i say, its always spot on in the mornings Confused
Hutchysrs50
PostPosted: 17:42 - 27 May 2009    Post subject: Reply with quote
yes, im sure they come with a gap, but somtimes you need to set the gap to suite your bike, to the amount the manual says.
Gilera SC 125 - Current
Ingah
PostPosted: 18:25 - 27 May 2009    Post subject: Reply with quote
Just a guess, but i suspect this could be related Wink
salty21
PostPosted: 18:33 - 27 May 2009    Post subject: Reply with quote
yes i see the logic there, but new plugs are £60, quite a lot of money for an off chance, how often do you get faulty plugs?
chillpill
PostPosted: 18:55 - 27 May 2009    Post subject: Reply with quote
more like 30 quid , one br9eix plug costs about 7-8 quid and youd defentleyu get a disconut for 4
chillpill
PostPosted: 18:57 - 27 May 2009    Post subject: Reply with quote
https://cgi.ebay.co.uk/4-X-NGK-IRIDIUM-SPARK-PLUGS-BR9EIX-PK4-MOTOCROSS-3981_W0QQitemZ200292741969QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item2ea260b351&_trksid=p3286.c0.m14&_trkparms=72:1683|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
35 quid for 4 there
i dunno what plug rating is standard for the cbr rr i just used 9 as an example
salty21
PostPosted: 19:36 - 27 May 2009    Post subject: Reply with quote
yes thats what i thought but they are quite a rare plug apparently(IMR9C9HES), which seems a bit silly in such a common bike Rolling Eyes got quoted 70-80 quid at all the local bike shops, managed to find some on the net for about £50 i think, then add postage your looking at £55.
only 2 results on ebay and both are showing 13-14 quid each lol
https://shop.ebay.co.uk/IMR9C9HES%20?_from=R40&_trksid=m38&_nkw=IMR9C9HES+&_naf=1
TUG
PostPosted: 21:54 - 28 May 2009    Post subject: Reply with quote
Unless its for a different bike... the plug your fitting for YOUR MODEL/YEAR BIKE should be correct... Rolling Eyes
Haz ER-5, innit!
TUG
PostPosted: 21:58 - 28 May 2009    Post subject: Reply with quote
If you fit them yourself the £30-50 hourly labour charge wont need paying... its easy to get at plugs when you try. I cant remember how to do them on your bike so i cannot advise on a HOW TO list.
The bike is injected, it should run everytime inless a sensor at any point of the system isnt connected correctly (air box, lambda, temp etc) if anyone of them is out then the bike will not run correctly.
Haz ER-5, innit!
salty21
PostPosted: 22:21 - 28 May 2009    Post subject: Reply with quote
i do fit them myself Laughing the quotes from the bike shops were for plugs only lol, they were asking £20 each plug
TUG
PostPosted: 22:44 - 28 May 2009    Post subject: Reply with quote
Sounds like they are trying to sell you diamond plugs? If cheap enough, try some plugs it wont do any harm will it really.
Haz ER-5, innit!
The last post was made 17 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 122.57 Kb
