Can I push my luck?
Scouse
PostPosted: 21:20 - 27 May 2009    Post subject: Can I push my luck? Reply with quote
I'm planning on going for an MOT and my rear tyre is a bit worn. Worn as in very close to the limit blocks in the middle and not much less on the sides.
Is that still passable?
When searching I've only found non specific answers of
'badly worn tyre's are a fail'
What does badly worn come down to also?
Skudd
PostPosted: 21:27 - 27 May 2009    Post subject: Reply with quote
IIRC the tread should be no less than 1mm for bikes, Cars it is 1.6mm
K0rnIsAFAGGOT This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Finglonga
PostPosted: 11:49 - 28 May 2009    Post subject: Reply with quote
If your not sure take it to the MOT place a week before and ask if it would pass. Then you know for sure.
Andy Sez....
F.Y.Y.F.F.
Darth
PostPosted: 12:08 - 28 May 2009    Post subject: Reply with quote
If it fails then buy a new one. Simples!
Fawbish
PostPosted: 12:19 - 28 May 2009    Post subject: Reply with quote
Sometimes you can pass with "Tyre on legal limit" andf they'll give you it with the promise of it gettin replaced
doggone
PostPosted: 12:32 - 28 May 2009    Post subject: Reply with quote
It might be worth simply telling them you're aware it needs changing very soon - better than trying to make out you haven't noticed.
JakeyR
PostPosted: 12:36 - 28 May 2009    Post subject: Reply with quote
Depends what MOT station ya go too, I'm all gurd 'cos one of my best mates is an MOT tester. Laughing
t121anf
PostPosted: 12:41 - 28 May 2009    Post subject: Reply with quote
if it's legal it should pass.
as previously said, thats 1mm in a continuous band across at least 3/4s of the tyre.
i'd be more concerned about getting 3 points than an mot if it doesn't meet this.
map
Mr Calendar
PostPosted: 13:06 - 28 May 2009    Post subject: Reply with quote
FWIW the legal requirement for motorcycle tread depth is 1mm across 3/4 of the tyre width and constant visible tread across 100% (a continuous band around the entire circumference).
However, for a moped then there's no minimum tread depth requirement. The tread just has to be visible.
You can check yourself here ([Laws RTA 1988 sect 42 & CUR reg 32]).
If caught on the road penalties are a Fixed Penalty Notice or report for prosecution, maximum £2500 and 3 penalty points. This can be per tyre.
HTH Thumbs Up
arry
PostPosted: 13:11 - 28 May 2009    Post subject: Reply with quote
It'll likely get an advisory
Peirre oBollox
PostPosted: 13:24 - 28 May 2009    Post subject: Reply with quote
why worry about an MOT fail, if in doubt just buy a new tyre.
the only difference between new & that very worn barely legal tyre your worried about will only matter when when your sliding down the road on your arse when its lost grip, or your pushing the bike home after a puncture or blow out.
If it was me I`d just change the tyre for my own piece of mind.
I change tyres when they`re squared off, and no where near the limit
PostPosted: 13:38 - 28 May 2009    Post subject: Reply with quote
Not everyone has the disposable money to 'just buy a new tyre'.
Grip is a sliding scale; a decent sports bike tyre low on tread will probably still have a lot more of it than many other bikes do with other tyres.
PostPosted: 14:02 - 28 May 2009    Post subject: Reply with quote
Compound in contact with road gives you grip. Not tread. Tread clears water in the highly unlikely situation that you hit standing water fast enough to aquaplane.
If you don't believe me, try riding a bike with knobbly road tyres on a wet road. Lots of tread, fuck-all grip.
I ride my motorway tyres almost to canvas.
If it's just off the wear bars, they'll probably give you an advisory to replace the tyre soon.
temeluchus
PostPosted: 14:52 - 28 May 2009    Post subject: Reply with quote
Yank the back wheel off and see if you can stick a part worn on. Also you can get reasonably good radials cheapish. Contiforce are cheap and quite good-went well on my GSXR 1100 which is similar power to your R6.
Fawbish
PostPosted: 15:20 - 28 May 2009    Post subject: Reply with quote
But a GSXR1100 is unlikely to handle as quickly as an R6 with a half decent rider on it. Good rubber or no rubber ftw!
Mark65
PostPosted: 15:51 - 28 May 2009    Post subject: Reply with quote
Alexander says "Simples" lol
jackw72
PostPosted: 16:06 - 28 May 2009    Post subject: Reply with quote
When I went for MOT the blokey said it had to be 1.5mm which I knew was bullschlaka.
I still have the tire as personal revenge.
OT get a new tire, you don't really have many other options as if you don't replace it then you will only be buying one in a few weeks.
08/11/2007 A2 Passed.
Suzuki GSXR 1000 K3
Rapid Training passed
Scouse
PostPosted: 16:08 - 28 May 2009    Post subject: Reply with quote
It's needed so that a)I can get to work this week and b)to take it to the guy I always go to, right next door to where I work and get it replaced a lot cheaper than anywhere round here.
Peirre oBollox
PostPosted: 17:01 - 28 May 2009    Post subject: Reply with quote
Scouse wrote:
It's needed so that:
Well ride it to work.
Take it next door to work
get tyre fitted.
Then take it for a MOT
Darth
PostPosted: 18:11 - 28 May 2009    Post subject: Reply with quote
I had just seen that advert before posting! Mr. Green
Scouse
PostPosted: 19:03 - 28 May 2009    Post subject: Reply with quote
get tyre fitted.
Work is 110 miles away.
Not so "simples".
Ariel Badger
PostPosted: 19:12 - 28 May 2009    Post subject: Reply with quote
G wrote:
grip is a sliding scale;
Very Happy
Peirre oBollox
PostPosted: 20:58 - 28 May 2009    Post subject: Reply with quote
local job then lol
Scouse
PostPosted: 10:43 - 29 May 2009    Post subject: Reply with quote
Got adviseries Dance!
The last post was made 17 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 127.4 Kb
