| ttr |
 ttr Crazy Courier
 Posted: 15:34 - 28 May 2009 Post subject: |
| ttr |
 ttr Crazy Courier
 Posted: 15:49 - 28 May 2009 Post subject: |
Can't think why they'd be using a 12,9 on a clutch spring, it isn't a high load application really.
How tight are you supposed to do it up according to the manual?
For M6x1.0 bolts you tighten to:
Grade 8,8 = 7.67 ft/lb (dry) or 5.75ft/lb (lubed)
Grade 12,9 = 13 ft/lb (dry) or 9.67 ft/lb (lubed)
So basically. If it's telling you to tighten it to 7ft/lb (84 inch/pounds), you really ought to be using an 8,8 anyway. If it's telling you to tighten to 10ft/lb (120 inch pounds), you need the 12,9. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ttr |
 ttr Crazy Courier
| _sketch_ |
 _sketch_ Scooby Slapper
| ttr |
 ttr Crazy Courier
The last post was made 17 years, 136 days ago. Instead of replying here, would creating a new thread be more useful? |
