SP1/2 owners, what's your running temperatures?
Seb
PostPosted: 21:43 - 28 May 2009    Post subject: SP1/2 owners, what's your running temperatures? Reply with quote
As per the title, what sort of typical temperatures does your SP1/2 sit at at various speeds? I'm finding mine creeping past 90 if I get stuck in traffic with it rapidly pushing 100+ if I have to stop for lights etc. 40mph+ and it's not a problem, I'll rarely see it go past 85 on an open road.
Cheers Thumbs Up
2010 Triumph 1050 Sprint ST
DynaMight
PostPosted: 22:49 - 28 May 2009    Post subject: Reply with quote
I really don't look at mine but I did look the other day while crawling along on a warm day and it was between 90-100.
s44678
Guest
PostPosted: 23:07 - 28 May 2009    Post subject: Reply with quote
Slightly off topic, but I was getting really paranoid that mine was overheating and thought I needed to change the coolant or something. Like yours, it seemed to shoot up really quickly if stopped at lights.
Turns out in the manual that I should only worry if it gets above 239F (115C) and if that happens to just turn the engine off and let it cool down. This is a) is a lot hotter than I thought it could take and b) contrary to popular advice on what to do if it is overheating.
So I would have thought your temps sound about right.
PostPosted: 23:09 - 28 May 2009    Post subject: Reply with quote
My S4 regularly hits 108, the mech at the dealer said not to worry untill it hits 120.
damz
PostPosted: 03:22 - 29 May 2009    Post subject: Reply with quote
luckily you guys got proper temp gauges i just have an incredibly vague dial that gets hard to read if its wet warm as it steams up , mine gets really hot (as most v4's appear to do) it needs some speed for the air to cool it down, stuck in the city centre in the summer and its almost off the scale all the time.
Current Bikes RVF400 - 94
Cars: RX7 FD, Eunos Roadster
PostPosted: 08:15 - 29 May 2009    Post subject: Reply with quote
Mine gets very hot very quickly in traffic too (B1H). I don't need to worry on mind until the temp gauge starts flashing and that happens at 120 IIRC.
I've had mine up to 109 or so before and wasn't pissing coolant out like some other bikes were.
duhawkz
PostPosted: 09:31 - 29 May 2009    Post subject: Reply with quote
My VFR800 vtec regularly reaches 105 when siting in traffic, the cooling fans come on till around 100
doggone
PostPosted: 09:47 - 29 May 2009    Post subject: Reply with quote
Because the coolant is under pressure it's normal to go well over 100C and that doesn't mean it's boiling.
Same principle as a pressure cooker.
Just don't take the cap off Very Happy
You should be making sure the rad isn't bunged up though, squirt hose through ideally from behind - brushing is risky, some detergent helps a lot.
It's amazing how good they are at sucking debris in, fibres and dust will really knock the efficiency down
St0rmer66
PostPosted: 11:27 - 29 May 2009    Post subject: Reply with quote
Sounds about the same as my RSV, I've seen it touch 100 before, the heat on my legs from the radiators confirmed the high reading! Laughing
:: Honda XR 125 L ('53) => Kawasaki GPZ 500S ('02) => Suzuki SV650S ('00) => Aprilia RSV-R ('51) ::
Seb
PostPosted: 18:43 - 29 May 2009    Post subject: Reply with quote
Cheers for the replies, I'm worried it's got a bit of a slow leak which has inturn been making me a little paranoid about the temperatures. The rads themselves are clean as a whistle and the bike generally sheds it's heat nice and quickly once I get moving again, it's just slow and stationary moments that have been a bit worrying at times.
Cheers Thumbs Up
PostPosted: 18:57 - 29 May 2009    Post subject: Reply with quote
The SP1/2 has side mounted rads that won't get bunged up as easily as front mounted ones.
My TT600 and S4 regularly do over 100. Fuel injected bikes seem to run hotter than their carburated brethren. Thumbs Up Smile
Sprout
PostPosted: 11:27 - 30 May 2009    Post subject: Reply with quote
Low 80's on the move, it'll quickly hit 105 when I first stop and then hover arround 100 when the fans kick in.
'03 Aprilia RS125 -> '89 Honda VFR400 nc30 -> '02 Honda CBR 600 FS -> '01 Honda SP1
TheFoxyDuke
PostPosted: 13:43 - 30 May 2009    Post subject: Reply with quote
My old CBR600 hit 114 in traffic one day.
I thought it was going to explode and the engine management light started to flash.
Soon came down when moving again but I later checked the fuse to the fan and found it had blown = no fan.
Couldn't tell when on the bike as it was hidden by the fairing. DOH Rolling Eyes
I'm not massively bothered by higher temperatures these days. The Dukes fans come on at 107, off again at around 98.
Have you checked the fuses / fans are working OK.
FoxyD
Currently : Ducati Monster S4R 2005, 996cc, Blue with Corse stripe, Open Carbon Clutch Cover (TokaTokaTokaToka), Marchesini 5 Spoke Wheels, 117BHP.
Wanted : Ducati 749S 2005 onwards.
Rate my Posts, You Sons of Bitches!
Thom
PostPosted: 18:27 - 30 May 2009    Post subject: Reply with quote
Thank fuck i've got a shitty air cooled diversion Razz
The last post was made 17 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 79.92 Kb
