power commander maps?zx6rr 03?!
bullet6
PostPosted: 18:35 - 29 May 2009    Post subject: power commander maps?zx6rr 03?! Reply with quote
just grabbed power commander off ebay but my bike seems worse off than before..
i put the full system custom airfilter one on from the dynojet site,just wondering if anyone with a zx6rr had any maps theyd like to share? iv got a stubby carbon slip on and a kn air filter on at the mo..
any help would be appreciated untill i can find the doe to take her into the shop Laughing
PostPosted: 18:55 - 29 May 2009    Post subject: Reply with quote
Downloaded maps are pretty pants TBH.
Before you do anything else make sure you check your air filter is clean and check your TPS setting. These can have a big bearing on the running of your bike and the way changes you make in the powercommander affect it too.
The only way you're really going to be able to use your powercommander effectively without a dyno session is by using a wideband datalogger. Using one of those you record RPS, TPS and exhaust O2 - you'll end-up with a better-running bike than a dynoed one.
bullet6
PostPosted: 19:48 - 29 May 2009    Post subject: Reply with quote
yea the filters good changed it the other day, dont know much about the throttle position...would that get messed up then with the power commander?
had a look at the data loggers theyr about the same price as a dyno run/mapping so i guess it makes sense Wink
cheers mate
PostPosted: 06:15 - 30 May 2009    Post subject: Reply with quote
cheers mate
The throttle position won't get messed-up by the powercommander, but if you are going to dyno the bike you need to check the setting of it before you go or coz if it's out the money spent at the dyno will be wasted.
What dataloggers you looking at?
The last post was made 17 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 41.25 Kb
