 bullet6 Derestricted Danger
 Posted: 18:35 - 29 May 2009 Post subject: power commander maps?zx6rr 03?! |
just grabbed power commander off ebay but my bike seems worse off than before..
i put the full system custom airfilter one on from the dynojet site,just wondering if anyone with a zx6rr had any maps theyd like to share? iv got a stubby carbon slip on and a kn air filter on at the mo..
any help would be appreciated untill i can find the doe to take her into the shop  |
 Posted: 18:55 - 29 May 2009 Post subject: |
Downloaded maps are pretty pants TBH.
Before you do anything else make sure you check your air filter is clean and check your TPS setting. These can have a big bearing on the running of your bike and the way changes you make in the powercommander affect it too.
The only way you're really going to be able to use your powercommander effectively without a dyno session is by using a wideband datalogger. Using one of those you record RPS, TPS and exhaust O2 - you'll end-up with a better-running bike than a dynoed one. ____________________ a.k.a 'Geri'
 Posted: 19:48 - 29 May 2009 Post subject: |
yea the filters good changed it the other day, dont know much about the throttle position...would that get messed up then with the power commander?
had a look at the data loggers theyr about the same price as a dyno run/mapping so i guess it makes sense
cheers mate |
