Dirtier than Jodie Marsh!....
TheFoxyDuke
PostPosted: 21:17 - 28 May 2009    Post subject: Dirtier than Jodie Marsh!.... Reply with quote
....were my calipers and pads. So I thought I'd treat them to a little springclean.
Now was able to get the pads out OK (Brembo's) although the little split oin that holds the anti-squeal plate was a PITA.
Now, thought I had some MucOff Brake disc cleaner left but seems I had run out when I cleaned my clutch plates last week. So used what I thought would be the next best thing or chain cleaner. Give the pads a bit of a run with sandpaper and fittedthem back in.
Tried the lever to get them seated properly and it seems to have more play than before and when I test rode the bike the action felt quite spongy. I thought it might have been the cleaner I used so went out and bought some more disc cleaner and give them all a good liberal coating in case I'd contaminated the pads. But no real improvement when I rode again. Confused
So do the pads need to bed in again once they have been cleaned / roughed up a little? If so, how long does that take?
Or have I accidently introduced some air and need to bleed the system?
I'm a pretty inexperienced spannerer tbh and seem to be learning by mistakes Rolling Eyes
FoxyD
Currently : Ducati Monster S4R 2005, 996cc, Blue with Corse stripe, Open Carbon Clutch Cover (TokaTokaTokaToka), Marchesini 5 Spoke Wheels, 117BHP.
Wanted : Ducati 749S 2005 onwards.
Rate my Posts, You Sons of Bitches!
nowhere.elysium
The Pork Lord
PostPosted: 22:15 - 28 May 2009    Post subject: Reply with quote
Sounds like air in the line to me.
Paulington
PostPosted: 22:19 - 28 May 2009    Post subject: Reply with quote
+1 For the above, bleed them brakes!
Mark65
PostPosted: 10:23 - 29 May 2009    Post subject: Reply with quote
Cant understand how air has got in if you havnt opened anything up with regard to brake system, what was the chain cleaner?? you used.
If you have opened the pistons up a bit to get the pads in they will need a few pumps to move back and if theres no fluid leak around the pistons the system should be sealed unless its coincidentel timing, but since it doesnt take too long to do might as well bleed them for the summer.
Mark
TheFoxyDuke
PostPosted: 20:05 - 29 May 2009    Post subject: Reply with quote
Mark
I agree. I can't see how any air was introduced but I've just give them a bleed and they feel much better when in the garage, but I haven't tried them on the road yet.
Oh, I also had to bleed using the nipple on the master cylinder at the end. I've also zip tied the lever back overnight as I've read that it helps expel any more bubbles.
So fingers crossed for tomorrow. Forecast nice for once as well Laughing
FoxyD
The last post was made 17 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 47.29 Kb
