| oggy1610 |
 oggy1610 Two Stroke Sniffer
| mad4it028 |
 mad4it028 World Chat Champion
| Barry_M2 |
 Barry_M2 World Chat Champion
| oggy1610 |
| DaveH |
 DaveH World Chat Champion
 Posted: 22:49 - 28 May 2009 Post subject: |
Have you taken up the gap between the engine and the frame by adjusting the castelated nuts? ____________________ https://www.timhastingsracing.co.uk/
ZX7R & ER6F |
| DaveH |
| oggy1610 |
| DaveH |
| oggy1610 |
| oggy1610 |
| oggy1610 |
| oggy1610 |
| oggy1610 |
| oggy1610 |
| oggy1610 |
| oggy1610 |
| Grayzo |
 Grayzo Borekit Bruiser
 Posted: 21:59 - 01 Jun 2009 Post subject: |
Hi martin,
I am not a mechanic, but am talking from experience, my brother had an exup 1000 and it developed very similar problems, my brother being very technical and also being an engineer pulled the motor and stripped it, and found the fault, which was a manufacturing fault, the fault being a crack around the circumferance of the crank, which was causing an imbalance and therefore the vibration, I hope that this is not the case for you in the finacintial sense, but if it is the fault I hope that I have helped you to solve the problem, good luck with it, ( I know it is a pain to check if I am Correct or not but it is the only thing that I can put it down to being the fault ) hope I have been of some help, good luck.Allan. ____________________ BULLDOG BASH 2009 - 6th, 7th, 8th and 9th OF AUGUST
had - NS125R current - FZR400RR EXUP (89) |
| oggy1610 |
| oggy1610 |
| oggy1610 |
 Posted: 08:31 - 04 Jun 2009 Post subject: |
Thought it was too good to be true. Got to work (21 miles) this morning only to find that the CCT had moved and the noise was back. GRRRRR!!!!!
So question now is does the CCT need to be replaced or is there something more serious going on inside the engine? I know one thing for certain, this takes the bike off the road for a fortnight. Double GRRRRRR!!!!!!  |
| Barry_M2 |
 Posted: 09:26 - 04 Jun 2009 Post subject: |
Yes, replace it. If its being pushed back then the teeth on it will be worn.
If you dont, you run the risk of it backing right off and allowing the cam chain to go slack and jump the cam sprockets. Then the pistons will demolish the valves (and themselves) which in turn will ruin the head and then thing start getting really expensive...
 ____________________ ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
https://www.bikechatforums.com/profile.php?mode=viewprofile&u=4332 |
| oggy1610 |
| oggy1610 |
| Scouse |
 Scouse World Chat Champion
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
The last post was made 17 years, 130 days ago. Instead of replying here, would creating a new thread be more useful? |
