Brake Caliper Problems
smegballs
PostPosted: 19:14 - 03 Jun 2009    Post subject: Brake Caliper Problems Reply with quote
Hi,
The brakes on my Superdream 1980 250cc are binding as a result disc gets very hot, poor ecomomy/performance etc etc....
Tried to simply strip caliper down to sort but can't remove the pins holding the pins in.
Tried WD, parallel punch etc etc, the damn things wont budge!
Any ideas how to get these out??
If not ill have to cut the body out and drill the studs.
The brake pins are 4.75 each for a little bit of metal with a hole in the end!!
Are they high tensile or anything??
Will making my own pins be fine or should I but Mr. Hondas finest??
Cheers, Rich
*edit*
https://i44.tinypic.com/zxp1rk.jpg
added pic to illustrate, I do have a hole to get to the pin far end with a punch however the pin does not protrude all the way thru' the caliper.
puremagic72
PostPosted: 20:23 - 03 Jun 2009    Post subject: Reply with quote
Presuming you have taken the caliper off completely, have you tried heating it up a bit, and giving it a wrack with a wooden mallet?
Baz. Thumbs Up Thumbs Up
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
Frost
PostPosted: 21:40 - 03 Jun 2009    Post subject: Reply with quote
Make sure you can get to the back of the pad's.
Those pins are held in place by something, either R clips in them, or they screw in.
If they are R clip type and you have remoed the clips, but corrosion in holding them in place, punch them out.
If they are screw in type and you have fucked the head, drill and retap them.
finpos
PostPosted: 21:50 - 03 Jun 2009    Post subject: Reply with quote
They may have a thread on them - an indentation in the head my be what's left of an allan key fitting.
f.
smegballs
PostPosted: 21:57 - 03 Jun 2009    Post subject: Reply with quote
Well just had fun in the garage....
Cut one side of the pins so I could split the caliper and the disassembled and drilled out the studs.
Those things were NOT coming out....
Even after drilling 3/4 of the stud out I tried to punch out the remainder...
Didn't budge!!
Looks like the only way was to get violent....
New pins and piston seal now then...
Piston Cleaned up OK
Rich
The last post was made 17 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.51 - MySQL Queries: 13 - Page Size: 43.53 Kb
