| carpetkarl |
 carpetkarl L Plate Warrior
| Danzio |
 Danzio Nova Slayer
 Posted: 15:19 - 04 Jun 2009 Post subject: |
im assume its a 2t, aerox's have always been 2t right?
im not sure how youd remove all the water..? if there's no bleed nut at all would there not be any other way of extracting it from the engine? such as using a hoover or one of those turkey basters and sucking it out of the crevises?
im uncertain what an aerox engine looks like, got any pics you can post so i can view further you problem?
as for lubrication im pretty sure when i had a 50 that these parts were lubricated, in what im also undure of. ill have a word with my brother, hes good with this and get back to you.
DONT FORGET PICTURES!  |
| Hutchysrs50 |
 Hutchysrs50 World Chat Champion
| ms51ves3 |
 ms51ves3 Super Spammer
| Danzio |
 Danzio Nova Slayer
 Posted: 15:46 - 04 Jun 2009 Post subject: |
there ya are these guys know the crack
nice one peeps  |
| Hutchysrs50 |
 Posted: 15:47 - 04 Jun 2009 Post subject: |
| carpetkarl |
 Posted: 09:06 - 05 Jun 2009 Post subject: |
cheers guys, got 90%+ of water out of engine, hope rest will evapourate or get blow out in steam.
I have e-manual on this, and no mention of oil in crank which seem weird to me, so thanks for info on drops of oil. all is falling into place down, now all I have to do is re-build and get it running again,
easy  |
| Hutchysrs50 |
| Hutchysrs50 |
 Posted: 11:10 - 05 Jun 2009 Post subject: |
- just drain all the water out
- take the water pipes off that go to the cylinder head.
- Take the coil off the spark plug.
- take the 4 cylinder head stud bolts off.
- take the head off (might be abit tough if it hasnt been off for a long time, just try not to stick a screw driver in there as it can chip/wear down that part of the cylinder making it leak.
- Slide the cylinder off, watching the piston doesnt get damaged
- take the old gasket off the base of the engine and replace.
- put some 2 stroke oil on the piston rings/small end bearing/cylinder (a thin layer round should be fine)
- make sure the piston rings are sitting in the correct place and slide the cylinder head back on (put the piston so its just touching the cylinder, squeeze the rings tight and let the cylinder go down, might take awhile, but it has to be done correct.
- replace all the gaskets on the top (you will know which ones go where)
- pretty much everything els in reverse order
Thats my guide on replacing gaskets, but the same kinda thing.
Also, a few things will be different for you, just make sure the arrow on the piston is pointing towards the exhaust, put a little bit of oil on the small end bearing.
think thats about it, Best of luck  ____________________ Gilera SC 125 - Current |
| TZRD350R |
 TZRD350R L Plate Warrior
| Hutchysrs50 |
The last post was made 17 years, 130 days ago. Instead of replying here, would creating a new thread be more useful? |
