| Noxious89123 |
 Posted: 00:04 - 07 Jan 2009 Post subject: How to derestricted your big bike from 33bhp |
The original thread I made when I did this was shite, as it was mostly me rambling along and a bit of guess work. I have since successfully derestricted my bike, so it's about time i made a better, clearer post about the subject, as the qustion crops up quite often.
The basic's of it are that you need to remove the fuel tank and airbox of your bike, to get to the carbs. How you do this depends on your bike, so get a Haynes and figure that part out for yourself!
Once you do that, you should see something like this;
https://img393.imageshack.us/img393/564/restrictorsjc9.jpg
These are the slides in the carb. They are not restrictors (I thought they were too at first. D'oh).
https://img172.imageshack.us/img172/2674/1004843v2tp3.jpg
There will be a washer in between each carb and the cylinder head, inside the carb rubbers. You will need to undo the clamps holding the rubbers onto the head so you can lift the carbs up. I lifted the carbs and rubbers off the engine and then stuck the end of a 1/4" extension bar into the hole in each washer and gently levered them out of the carb rubbers. Easy peasy. It worked fine on my bike, but be careful not to damage or split the carb rubbers! (Getting the washer back in this way would be a real pain in the arse, so be sure before you do this.)
https://img512.imageshack.us/img512/1551/1004900za3.jpg
These are the "carb cap" part of the restriction that is mentioned on the FI International certificates.. They sit under the carbtops but ontop of the rubber diaphragm. They stop it (and thus the carb slide and needle) from lifting up / opening up fully.
I didn't know about these (Because there is bugger all information about derestriction on the internet!). I only found out when I had the bike service and the mechanic mentioned it and asked if I wanted the job doing properly. He took them out for £20 under the counter.
Be careful taking these out, because the diaphragms are very delicate and can tear. (Or so I was told. Didn't do this part myself, so couldn't say.)
Note: No doubt I'll have made some typo's in there somewhere, or something won't be quite explained clearly etc. If so, let me in here or by PM and i'll edit it!
Hope this helps! ____________________
| m0l0t0v |
 m0l0t0v World Chat Champion
 Posted: 01:32 - 07 Jan 2009 Post subject: |
Also, to be aware, not all bikes have the rubber parts.
My Hornet didn't. It jsut had the washers in. And it was definately full power after that  ____________________ '99 Hornet 600 , VFR 400 NC30 '92 , Kasawamasaki GT 550 , '98 Hornet 600
**\Tarmacsurfer/** said: It's that immaculately manly coiffure of yours isn't it. One glimpse of your virile locks and the punters can't wait to buy whatever it is you suggest, as it might let them be just a little bit like the Adonis that is our very own Molly Doovydoo said: Its not my fault I can't get it up properly, I just wasn't blessed  |
| Purplepill |
 Purplepill Trackday Trickster
 Posted: 01:47 - 07 Jan 2009 Post subject: |
Cheers for clearing that up for me I removed my own washers but was always curious as to what the 'carb caps' were, dont think my bike (CBR600F) had them but had heard of them being mentioned on other bikes.
Edit: Ah sh*t, it appears this IS a cbr600 although mine was a 95'....according to your origional de-restriction thread it uses a different engine? If the washers were out but the caps in, do you have any idea what power it would make roughly? I pinned it to just over 150 (on the speedo ) so im guessing it didnt have caps, but curious, if it could still make 80 odd bhp with the caps in I guess its possible? ____________________ ''He had the confidence of a baby-goat dared to tickle a t-rex's nutsack'' |
| Noxious89123 |
 Posted: 21:28 - 07 Jan 2009 Post subject: |
If you hit over 150, i'd say it was making full power. Mechanic saying my bike would only be making about 50~60bhp.
Also, they're hard plastic, not rubber. Just to clear that up  ____________________
| Purplepill |
 Posted: 02:33 - 08 Jan 2009 Post subject: |
Nice one, it was definatly full power then, I dont have it anymore so was just curious/double checking . ____________________ ''He had the confidence of a baby-goat dared to tickle a t-rex's nutsack'' |
| linolino1 |
This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
 linolino1 L Plate Warrior
| Naggedalot |
 Naggedalot Renault 5 Driver
| Noxious89123 |
| ms51ves3 |
 ms51ves3 Super Spammer
| Noxious89123 |
 Posted: 22:25 - 03 Jun 2009 Post subject: |
That's a pretty good point, didn't think of that
Anyways, FI is for fag0ts.  ____________________
| binge |
 binge Emo Kiddy
 Posted: 22:33 - 03 Jun 2009 Post subject: |
| ms51ves3 |
| Danzio |
 Danzio Nova Slayer
 Posted: 15:14 - 04 Jun 2009 Post subject: |
the TL is a beautiful bike though
pleanty fast too  |
| Noxious89123 |
| binge |
 binge Emo Kiddy
 Posted: 22:59 - 04 Jun 2009 Post subject: |
| Noxious89123 |
 Posted: 23:03 - 04 Jun 2009 Post subject: |
You can't be suggesting your pitbike is more pimp than an LC?
That would require a power level over 9000 ____________________
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| Noxious89123 |
 Posted: 23:07 - 04 Jun 2009 Post subject: |
Yeah but everyone knows that the 350 is the shizzle.
Binge, put an LC motor in your pit bike  ____________________
| nowhere.elysium |
| binge |
 binge Emo Kiddy
| Jrod |
 Jrod Page 3 Girl
 Posted: 00:11 - 05 Jun 2009 Post subject: |
| Adrian89 |
 Adrian89 Nova Slayer
| Adrian89 |
| Jrod |
 Jrod Page 3 Girl
 Posted: 01:02 - 05 Jun 2009 Post subject: |
I did once dream of restricting a 12r! I got called mad to consider it (i wasn't gonna keep them in long ) |
| c_dug |
 c_dug Super Spammer
The last post was made 17 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
