cg was running badly and now packed in
Rottweiler
PostPosted: 15:29 - 05 Jun 2009    Post subject: cg was running badly and now packed in Reply with quote
right my cg isnt working
when i kick it up it stalls......its like the power is restricted, when i ride i hear pinging sounds ?
when i get it running i have to keep the revs high or its just cuts out...wont idle anymore
dont have a clue whats up with it. Was told to change the points on it so i did with the help of my dad but that made no difference...new spark plug the same happened.
it backfired whilst riding and then packed in and i couldnt get it started again.
any ideas ?
much appreciated Thumbs Up
were: piaggio nrg..ybr 125
now: cg 125
The Artist
PostPosted: 15:35 - 05 Jun 2009    Post subject: Reply with quote
Check timing
Check colour of spark plug
Check carb for dirt. (may need cleaning)
prawny1
PostPosted: 15:52 - 05 Jun 2009    Post subject: Reply with quote
check battery charge and valve clearences, if it still plays up strip the carb down for a good clean (might aswell check the fuel tap is flowing right whilst your at it).
for valve clearance check out this site:
https://hondacg125.awardspace.com/valve_clearance.htm
also if its a points model, check the points.
ToGGoT
PostPosted: 16:16 - 05 Jun 2009    Post subject: Reply with quote
Check fuel for leaks/blockages.
Check Spark Plug Colour/Condition.
Also, check for any obvious air leaks.
Agree with allymoss - Have a look at the timing.
ToGGoT
2005 BMW R1150R
Rottweiler
PostPosted: 17:15 - 05 Jun 2009    Post subject: Reply with quote
cheers guys i will let you know 2morrow when ive had a look Thumbs Up
now: cg 125
wreckage
PostPosted: 18:45 - 05 Jun 2009    Post subject: Reply with quote
I'm going to be nice now because it takes a lot more inteligence than just saying you are a bellend or the like. and as your dad helped you with a simple procedure like changing a set of points on a CG125 you're obviously a kid..
Now on the the Bike, your CG has points so it's a bloody old one as they've had CDI for about 18 years and also if I'm not too much mistaken you have a pushrod valve opening system so after so long there is a chance they could have bent or they might just be severely worn which will put your timing out and you also said you hear a pinging sound when riding which could also point towards a pushrod problem as there is a guide which the rods go through and the pinging sound could be one of the rods hitting the guide,
So once you've done all the simple checks and found it's still not working I suggest you have a look inside and check your rods..
One day I'll take my test again, honest
Rottweiler
PostPosted: 19:11 - 05 Jun 2009    Post subject: Reply with quote
yeah riding without a licence is intelligent well in Thumbs Up
am 18 btw some would say i am a kid others wouldnt im not fussed.
but cheers for the info on the rods though as you can tell i dont know much about it lol
now: cg 125
wreckage
PostPosted: 19:32 - 05 Jun 2009    Post subject: Reply with quote
I never said it was Intelligent, i just said i don't care but that doesn't matter now it's over and done with..
When you get to nearly 40 it's hard to see anyone under the age of 20 as anything but a kid, but at least you ain't riding a poxy scooter so thats ok..
Your CG is it made in japan or brasil?
seriously tho i didn't think there was any of the old Points ignition cg's left anymore,
But even i learned something new about the cg the other days and thats that it now has a disk brake up front..
Whats your riding style like?
wizzzard
PostPosted: 20:48 - 05 Jun 2009    Post subject: Reply with quote
Agree with wreckage on this one and prawny1 with the valve clearance's. Also have a look at your valve springs while the heads off one may have broken.
Rottweiler
PostPosted: 21:35 - 05 Jun 2009    Post subject: Reply with quote
its a jap one Thumbs Up
its is old lol 19 years i think but bought of a guy who had looked after it really well its in good nick Smile thats the reason i got it.
riding style ermm kinda slow due to weak brakes drum front and back Thumbs Down
now: cg 125
wreckage
PostPosted: 22:11 - 05 Jun 2009    Post subject: Reply with quote
Kinda ouch,
Just lucky then the CG is a very simple engine to work on, pushrods and two valves, springs and a set of points...
wizzzard
PostPosted: 22:12 - 05 Jun 2009    Post subject: Reply with quote
If you get stuck for any parts i have 2 pretty old cg engines knocking around so give me a shout Thumbs Up
The last post was made 17 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 73.4 Kb
