'performance air filters'
yuri2085
PostPosted: 15:21 - 07 Jun 2009    Post subject: 'performance air filters' Reply with quote
Is it worth buying items such as this?
They are significantly more expensive than 'normal' air filters, the advantage of it being washable seems good but also after fitting one would the bike require rejetting and such things?
edit: there are also performance air filters that arent made of foam and they say to clean them you need a kit and oil and all sorts so if these foam ones work it looks like a good thing. But is it really worth it over a stock filter?
Finglonga
PostPosted: 15:26 - 07 Jun 2009    Post subject: Reply with quote
Depends on the bike and what else it has had done to it. If its a 2stroke then forget it as you will spend the rest of your life trying to get it running right. Wink
Andy Sez....
F.Y.Y.F.F.
yuri2085
PostPosted: 15:31 - 07 Jun 2009    Post subject: Reply with quote
Its a 4 stroke (bandit 600) and hasnt had performance upgrades (the exhaust might be but i dont think so)
Pernig
PostPosted: 21:43 - 07 Jun 2009    Post subject: Reply with quote
If you don't need one I wouldn't waste your money on it. If your old air filter is shagged then I would recommend either getting the original part or a standard K&N replacement. It's a bonus that you can wash it, you get the oil for it in the box and barely makes a difference to the state of tune, just makes it slightly louder.
H100 Breaking for spares
yuri2085
PostPosted: 22:28 - 07 Jun 2009    Post subject: Reply with quote
Just bought standard part, didnt realise K+N came with the oil thought that might have been a hassle.
Thanks for the help guys.
The View Askew
PostPosted: 23:53 - 07 Jun 2009    Post subject: Reply with quote
Without other modifications, as far as my knowledge goes less air resistance will give better throttle response, and a LITTLE bit more power higher in the rev range when air draw is peaking, not much else, it does make a difference though, albeit very small and will be louder.
Coupled with a sports exhaust and more fuel you will see a small performance enhancement, but more fuel will be necessary.
The last post was made 17 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 51.33 Kb
