Carb balancing tool
RS2MATRIX
PostPosted: 22:39 - 13 Jun 2009    Post subject: Carb balancing tool Reply with quote
Here
Are these as effective as any other carb balancing tool on the market?
Cheers, nick
Reiju RS2 Matrix
Kawasaki ZXR400
Flip
PostPosted: 22:52 - 13 Jun 2009    Post subject: Reply with quote
I think you should be the official BCF guinea pig. Very Happy Thumbs Up
PostPosted: 23:20 - 13 Jun 2009    Post subject: Reply with quote
It's a length of clear hose and two cable ties in a box.
It's called a manometer and is a VERY accurate way of synching your carbs. Much more accurate than even very expensive, mercury based vacuum guages.
I'll save you some money though.
Go to a hardware shop and buy about 4 metres of clear plastic tubing, a handful of cable clips and a bit of wood to attach it to.
Now click on the following link:
https://www.powerchutes.com/manometer.asp
KevTM
PostPosted: 23:31 - 13 Jun 2009    Post subject: Reply with quote
Use a set just like that myself, work a treat. Only thing I've noticed is after a while (not sure if it's a film of oily fumes or whatever) but the ball has gotten a wee bit sticky in the tube (not much really), notchy-like, but still accurate enough and should be easy enough to clean out if need be.
PostPosted: 23:39 - 13 Jun 2009    Post subject: Reply with quote
You don't need a ball if you use coloured oil. Tweak it until the two columns of oil are next to one another.
If there is a lot of up and down movement, you sometimes need to kink or compress the tubing slightly as it comes off the carb to damp it down. A G-clamp works well. Tighten it down until the movement is reduced to a minimum (although you should still see a slight up and down movement of the oil column, if there's none, you did it up too tight).
The last post was made 17 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 44.44 Kb
