| RS2MATRIX |
 RS2MATRIX Spanner Monkey
 Posted: 22:39 - 13 Jun 2009 Post subject: Carb balancing tool |
Here
Are these as effective as any other carb balancing tool on the market?
Cheers, nick ____________________ Reiju RS2 Matrix
Kawasaki ZXR400 |
| Flip |
 Flip Super Spammer
 Posted: 22:52 - 13 Jun 2009 Post subject: |
I think you should be the official BCF guinea pig.  |
| stinkwheel |
 Posted: 23:20 - 13 Jun 2009 Post subject: |
It's a length of clear hose and two cable ties in a box.
It's called a manometer and is a VERY accurate way of synching your carbs. Much more accurate than even very expensive, mercury based vacuum guages.
I'll save you some money though.
Go to a hardware shop and buy about 4 metres of clear plastic tubing, a handful of cable clips and a bit of wood to attach it to.
Now click on the following link:
https://www.powerchutes.com/manometer.asp ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| KevTM |
 KevTM World Chat Champion
| stinkwheel |
 Posted: 23:39 - 13 Jun 2009 Post subject: |
You don't need a ball if you use coloured oil. Tweak it until the two columns of oil are next to one another.
If there is a lot of up and down movement, you sometimes need to kink or compress the tubing slightly as it comes off the carb to damp it down. A G-clamp works well. Tighten it down until the movement is reduced to a minimum (although you should still see a slight up and down movement of the oil column, if there's none, you did it up too tight). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 17 years, 132 days ago. Instead of replying here, would creating a new thread be more useful? |
