aprilia rs50
Ricky047
PostPosted: 22:56 - 18 Jun 2009    Post subject: aprilia rs50 Reply with quote
Hi I was wondering if anyone was able to help me
have bought an oldaprilia rs50 1999 for my wee brother for his 16th B-day
I bought te bike for £200 and was told that i was seized. I dont know anything about bikes but I fancied a challange lol
Anyway to cut a long story short. I charged the battery and tried the bike after 5 mins it started up. It has enough power to take me up the road and back at 10mph but something sounds wrong.
The engine it very noisy. I removed the spark plug and there seems to be plenty of compression. The noise ounds like something is grinding or lose in the bottom of the engine
So where do I go from here. Any help would be great
[email protected]
Ps take it easy with replys im only a beginner lol
steo
PostPosted: 18:21 - 19 Jun 2009    Post subject: Reply with quote
sounds like your crankshaft is fcuked at the very least & as for the compression, i would say you should be doing more than 10mph if it was any good. your going to have to pull the engine out of the bike so get yourself a good workshop manual. if you don't have one then you can download the one for your bike from the thread at the top of the workshop page. to be honest, my advice to you would be to try and pick up a decent 2nd hand engine. aprilla parts are expensive plus your time & the rebuild will probably cost more than the bike is worth. plenty of spares on fleabay, hope this helps.
hectashouse
PostPosted: 19:48 - 19 Jun 2009    Post subject: Reply with quote
when i first got my jetforce moped it only did 20mph and was derestricted, turns out the piston rings was on there way out lol
just thinking maybe its whats wrong with your rs50 ?
hecta Cool ..
98" Honda xr125 (sold), 56" Peugeot Jetforce 50
CBT = done 24/01/09
Ricky047
PostPosted: 22:57 - 19 Jun 2009    Post subject: Reply with quote
Was going to get the loan of a compression tester what sort of results would I be looking for if it was working correctly
steo
PostPosted: 23:19 - 19 Jun 2009    Post subject: Reply with quote
anything over 90psi or else its probably a robore & new piston. im not even sure if those barrels can be rebored, they maybe those nickel plated ones but i'm not a 100% sure.
Ricky047
PostPosted: 23:48 - 19 Jun 2009    Post subject: Reply with quote
Will check it out and let you know. Many thanks
I have been reading the manual and sounds like the main bearings could need replaced but im only guessing at this. Does this sound feasible
steo
PostPosted: 00:09 - 20 Jun 2009    Post subject: Reply with quote
that heavy rumbling noise from the bottom of your engine that you described in an earlier post is more than likely worn main bearings but if you're doing an engine rebuild then these will be replaced anyway. you can check for play in them & i'm probably going to get crucified on these pages for telling you this but remove the left engine casing. stick a vicegrips onto the nut in the middle of the flywheel which screws onto the crank & see if you can feel any up & down movement. if you can then you know your mains are banjoed for sure.
Ricky047
PostPosted: 06:51 - 20 Jun 2009    Post subject: Reply with quote
Will try that tonight thanks again for your help. Will keep in touch to let you know how im getting on lol
The last post was made 17 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.26 - MySQL Queries: 13 - Page Size: 53.85 Kb
