baffle kit....is it really effective???
garyboy-palaboy
PostPosted: 04:46 - 20 Jun 2009    Post subject: baffle kit....is it really effective??? Reply with quote
ive seen this item on our local website mc ads....
does this item, REALLY increase bhp in your bike?
did someone tried to install this on their bike?
hope to gets some opinions from our gurus......
here's the description.....
Why spend a leg and an arm on slip-on's? Comparable sound and performance plus keep the Factory Look and have huge savings for other modifications!
Installing this kit will give you about 4-6 hp and 5 lbs of torque.
Pre-Cut for a perfect fit.
Included with our kits is baffle packing material.
Saves you about 2 lbs of total weight compared to the OEM exhaust baffle.
What is a Baffle Kit?
A Race Baffle replaces your OEM Baffle. What this does is increase exhaust airflow, which helps performance and improves sound quality. The sound and performance gains are very similar to expensive slip-on's.
https://i220.photobucket.com/albums/dd304/garyboy_palaboy/ulo/bafflekit.jpg
BEFORE AND AFTER VIDEO
BONE STOCK:
https://www.youtube.com/watch?v=Tclp0NQqlT8
AFTER INSTALLATION
https://www.youtube.com/watch?v=Vp5hjV1t1dU
instigator
PostPosted: 06:33 - 20 Jun 2009    Post subject: Re: baffle kit....is it really effective??? Reply with quote
You don't need to be a Guru to see that it's horse shit.
PostPosted: 08:27 - 20 Jun 2009    Post subject: Re: baffle kit....is it really effective??? Reply with quote
That's possible - but a lot of "expensive slip-on's" can often actually reduce power! If used in combination with fueling and air-filter changes, an increase in power can be achieved.
PostPosted: 19:21 - 20 Jun 2009    Post subject: Reply with quote
More likely to see a slight increase just by having new baffling in there than anything, and that's only if yours is old.
Ariel Badger
PostPosted: 20:29 - 20 Jun 2009    Post subject: Reply with quote
Well I am convinced by the evidence of those videos.
PostPosted: 20:33 - 20 Jun 2009    Post subject: Reply with quote
Sounds like they've just put less baffling in there than there was before.
It'll make it louder yes, but it'll introduce huge flat spot(s) into the power curve and drop the peak power by a couple of bhp. I don't think it's the sort of thing you can get around by fuelling mods either.(At least not in my experience)
carlperkins00...
PostPosted: 21:25 - 20 Jun 2009    Post subject: Reply with quote
if you want a bike with more BHP.. just save up and buy one. Laughing
that baffle makes it sound abit weird too.. its not a bassy sound, its a higher pitch.
The last post was made 17 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 52.96 Kb
