Valve clearances
c_dug
PostPosted: 19:24 - 22 Jun 2009    Post subject: Valve clearances Reply with quote
Planning on doing my valves soon, the bike has been very rattly and running rough, plus I have no idea when they were last checked. The bike is a 1998 GPZ500s by the way
I have done the valves on a 2 valve 125cc single before, never on anything like my bike though, is it a bad idea for me to attempt this myself?
Also will I definetly need a new gasket for the valve cover?
I am looking at my haynes manual at the moment and to be honest it seems fairly simple, the same as the 125 just more of it Laughing
Also will I need the special tool for the locking nut on the adjuster or will I be able to do it without, just with a little more fiddling?
Thanks
c_dug
steo
PostPosted: 19:41 - 22 Jun 2009    Post subject: Reply with quote
correct me if im wrong but i'm nearly sure the kwacker has shims as opposed to an adjustable tappet. if this is the case then you may have to replace some shims if the old ones are worn & measure them up.
c_dug
PostPosted: 19:44 - 22 Jun 2009    Post subject: Reply with quote
Nope, haynes says nothing about shims so i'm guessing it is tappets or whatever the other type is called Laughing
Plus the images look like what I have done before, and I wouldn't have a clue with shims so im guessing it is the tappet one.
c_dug
PostPosted: 19:49 - 22 Jun 2009    Post subject: Reply with quote
GPZ500 is screw and locknut valves.
The rocker cover gasket is rubber and should be OK to reuse. What you likely will need though are a pair of replacement rubber O rings for the water pipes into the head (one metal pipe either side of the cam chain tunnel, which both bolt to the rocker cover), as although you might get away with them if you don't have any spare then Murpheys law will apply.
Biggest problem is getting the rocker cover off on the GPZ500, with the throttle cables rubbing closely over it and the coils reducing the space to lift it off. Probably worth unbolting the coils and disconnecting the throttle cables before you take off the rocker cover.
c_dug
PostPosted: 19:53 - 22 Jun 2009    Post subject: Reply with quote
Out of interest would a worn CCT cause similar running issues?
c_dug
steo
PostPosted: 19:58 - 22 Jun 2009    Post subject: Reply with quote
was thinking of the gpz 550 but the 500 should be handy enough to do. keith is right, like the gt & gpz it's much easier to work on the kwacker if you take the coils off. the rocker cover requires a bit of jockeying around to remove it.
PostPosted: 20:00 - 22 Jun 2009    Post subject: Reply with quote
Cam chain tensioner out will result in a slappy noise.
On these engines there is also a primary drive chain to slap around and there isn't a tensioner on that. When it wears you just have to replace it (engine strip job).
c_dug
PostPosted: 20:17 - 22 Jun 2009    Post subject: Reply with quote
I guess i'll just do the valves and carbs and see if there is an improvement then, hopefully its nothing too major, the bikes not worth enough to go spending bit bucks on it Sad
c_dug
Mudskipper
PostPosted: 11:46 - 30 Jun 2009    Post subject: Reply with quote
[minihijack]Anything I should note with regards to checking the clearances on my GSXR750G? Was hoping to reuse the main rocker cover gasket, but should I replace the 4 (plug hole?) o-rings, d'you think? Hoping the sort them in a weekend, so trying to anticipate any potential problems.[/minihijack]
PostPosted: 12:00 - 30 Jun 2009    Post subject: Reply with quote
No done an early GSXR, but the engine is basically the same as the Bandit. You can reuse the rubber rocker cover gasket. Some people seem to stick them in place with silicon sealant (if you do be careful not to use too much).
arry
PostPosted: 12:31 - 30 Jun 2009    Post subject: Reply with quote
c_dug
You're still welcome to come have a listen over mine mate, or even a ride of it if you've got riding other bikes.
PostPosted: 13:23 - 30 Jun 2009    Post subject: Reply with quote
Agreed. Do this. Failure to replace the o-rings will result in the sparkplug tunnels filling up with coolant which then drains out through a small hole between the fake cooling fins on the side of the head.
You should only really need a spanner and a couple of screwdrivers once the tank is off.
As said, removing the coils only takes a couple of minutes and makes the job much easier.
Don't forget to drain down the coolant before removing the hoses Wink (sounds obvious.)
Balancing the carbs quietens them down a lot but they are a rattly engine at the best of times. I never heard of the primary chain actually going on one and it's almost certainly more expensive to fix than buying a good, second hand motor. As such my suggested solutions are:
1) Louder exhaust.
or
2) Earplugs.
StevRS
PostPosted: 13:48 - 30 Jun 2009    Post subject: Reply with quote
Not read the posts so forgive repetition.
No need to replace the gasket - torque it properly though.
The coolant pipes run through the valve cover - drain it first! The coolant pipes running through the valve cover are interferance fit - they will be tough to get out (mine are truly mangled after beating them out) and probably need new o-rings.
The valves aren't shimmed - nice and easy. Be sure it's cold though, preferably not ridden that day or it'll screw up the measurements.
MV Agusta Brutale 800 RR, Unfinished 1978 XS250
The last post was made 17 years, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 86.54 Kb
