| c_dug |
 c_dug Super Spammer
 Posted: 18:24 - 22 Jun 2009 Post subject: Valve clearances |
Planning on doing my valves soon, the bike has been very rattly and running rough, plus I have no idea when they were last checked. The bike is a 1998 GPZ500s by the way
I have done the valves on a 2 valve 125cc single before, never on anything like my bike though, is it a bad idea for me to attempt this myself?
Also will I definetly need a new gasket for the valve cover?
I am looking at my haynes manual at the moment and to be honest it seems fairly simple, the same as the 125 just more of it
Also will I need the special tool for the locking nut on the adjuster or will I be able to do it without, just with a little more fiddling?
Thanks
c_dug ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| steo |
 steo Nova Slayer
| c_dug |
 c_dug Super Spammer
 Posted: 18:44 - 22 Jun 2009 Post subject: |
Nope, haynes says nothing about shims so i'm guessing it is tappets or whatever the other type is called
Plus the images look like what I have done before, and I wouldn't have a clue with shims so im guessing it is the tappet one.
 Posted: 18:49 - 22 Jun 2009 Post subject: |
GPZ500 is screw and locknut valves.
The rocker cover gasket is rubber and should be OK to reuse. What you likely will need though are a pair of replacement rubber O rings for the water pipes into the head (one metal pipe either side of the cam chain tunnel, which both bolt to the rocker cover), as although you might get away with them if you don't have any spare then Murpheys law will apply.
Biggest problem is getting the rocker cover off on the GPZ500, with the throttle cables rubbing closely over it and the coils reducing the space to lift it off. Probably worth unbolting the coils and disconnecting the throttle cables before you take off the rocker cover.
| c_dug |
 c_dug Super Spammer
| steo |
 steo Nova Slayer
| c_dug |
 c_dug Super Spammer
 Posted: 19:17 - 22 Jun 2009 Post subject: |
I guess i'll just do the valves and carbs and see if there is an improvement then, hopefully its nothing too major, the bikes not worth enough to go spending bit bucks on it
| Mudskipper |
 Mudskipper World Chat Champion
| Blau Zedong |
 Blau Zedong Banned
| arry |
 arry Super Spammer
| StevRS |
 StevRS Scooby Slapper
The last post was made 16 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
