Feeler gauges - checking valve clearances
Swim41
PostPosted: 19:21 - 23 Jun 2009    Post subject: Feeler gauges - checking valve clearances Reply with quote
Currently checking the valve clearances on my Divvy 600. Two questions:
Is it OK to combine two thicknesses of feeler gauge, for example an 0.15mm and a 0.06mm to get a 0.21mm. Can I trust the result?
Second query: How much drag should I be looking for when withdrawing the gauge, is it just the barest noticable resistance?
thanks
Ben
Yamaha XJ600N
iooi
PostPosted: 19:50 - 23 Jun 2009    Post subject: Reply with quote
Yes using 2 to make up the correct tollerance is fine.
Barest noticable resistance, sound about right.
MaybeGuy
PostPosted: 19:51 - 23 Jun 2009    Post subject: Reply with quote
its ok to combine feeler gauges. they do it with slip gauges which are the same sort of thing.
not sure why you'd need to though, i thought the clearances were like 0.25mm?
you should feel a little resistance when its right, ie: doesnt just slot in.
Blue_SV650S
PostPosted: 20:26 - 23 Jun 2009    Post subject: Reply with quote
As said by others, no problem combining! Thumbs Up
As for resistance, is the divvy bucket and shim or tappets?
it's kinda summin you just get a feel for, but what I tend to do with tappets is select one off the smallest setting i.e. if the manual says 0.19-0.21, I'd select a 0.20. I'd then put the feeler into the tappet gap, I'd then do up the tappet adjuster until I can't pull the gauge out. Then whilst pulling on the gauge, unscrew the adjuster until the gauge slips out. I'd then put the gauge back in and lock the adjuster off. I'd then check the gauge still comes out (if not it has tightened slightly in the doing up).
I'd then try slipping in a 0.19 and seeing how easily that slides in, I'd then try and slide in a 0.21, if I can slide in a 0.21, then I'd do it up slightly until I can't get the 0.21 in, the 0.2 slides in ok, but a but sticky the 0.19 slides in with only a bit of resistance. By doing it this way you KNOW you don't have them too tight or too loose and don't really NEED to have a feel for the resistance required Thumbs Up
NOTE: With tappets the gaps will open over time, with shims they close. So I'd set tappets on the minimum setting, shims on the largest! Thumbs Up
Rockhopper
PostPosted: 21:06 - 23 Jun 2009    Post subject: Reply with quote
Get a telephone directory, slide the feeler gauge into the pages, thats what it should feel like when the clearance is correct.
iooi
PostPosted: 18:14 - 24 Jun 2009    Post subject: Reply with quote
Shims Thumbs Up
Blue_SV650S
PostPosted: 21:52 - 24 Jun 2009    Post subject: Reply with quote
Shims Thumbs Up
In which case, the doing up tappets stuff is of no use!! Laughing
So I'd go for upping gauge until it won't go in, then beck down until it slides in ok. You won't be too far off the mark at that point.
I like the telephone book idea, but if you put the gauge between the top two leafs, its not gonna give you the right feel (I am being silly, its obvious he meant somewhere in the middle or down the bottom Wink).
Swim41
PostPosted: 22:29 - 24 Jun 2009    Post subject: Reply with quote
Thanks for the help chaps - I though the phone book thing was a great tip. I've checked the clearances, then asked a mate to check them just to be sure, got virtually identical results.
Next it's out with the shims, and a play around with Geri's rather ace Shim Calculator.
Yamaha XJ600N
StevRS
PostPosted: 14:03 - 25 Jun 2009    Post subject: Reply with quote
Agree with all the above, but make sure the bike's cold when you check them.
Ideally, don't run it for a day before checking valve clearances or you might get duff readings.
MV Agusta Brutale 800 RR, Unfinished 1978 XS250
Flash Gordon
PostPosted: 09:17 - 26 Jun 2009    Post subject: Reply with quote
Really great topic!!
Some really good advice there
Going off to check mine now
Thom
PostPosted: 12:52 - 26 Jun 2009    Post subject: Reply with quote
by the way, rattley shims on a divvy are normal.
just incase you were checking for that reason.
I chanegd my shims to cure the rattling and simply made it worse by bringing them all intoo spec Embarassed
Swim41
PostPosted: 20:38 - 26 Jun 2009    Post subject: Reply with quote
Nah, just are part of routine maintainance. The bike is at 23k, should have been done at 16k. Managed to get them all out, think I will have to order a couple from wemoto.
Yamaha XJ600N
The last post was made 17 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 74.05 Kb
