| Swim41 |
 Swim41 Trackday Trickster
| iooi |
 iooi Super Spammer
 Posted: 19:50 - 23 Jun 2009 Post subject: |
Yes using 2 to make up the correct tollerance is fine.
Barest noticable resistance, sound about right. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 19:51 - 23 Jun 2009 Post subject: |
its ok to combine feeler gauges. they do it with slip gauges which are the same sort of thing.
not sure why you'd need to though, i thought the clearances were like 0.25mm?
you should feel a little resistance when its right, ie: doesnt just slot in. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Blue_SV650S |
 Posted: 20:26 - 23 Jun 2009 Post subject: |
As said by others, no problem combining!
As for resistance, is the divvy bucket and shim or tappets?
it's kinda summin you just get a feel for, but what I tend to do with tappets is select one off the smallest setting i.e. if the manual says 0.19-0.21, I'd select a 0.20. I'd then put the feeler into the tappet gap, I'd then do up the tappet adjuster until I can't pull the gauge out. Then whilst pulling on the gauge, unscrew the adjuster until the gauge slips out. I'd then put the gauge back in and lock the adjuster off. I'd then check the gauge still comes out (if not it has tightened slightly in the doing up).
I'd then try slipping in a 0.19 and seeing how easily that slides in, I'd then try and slide in a 0.21, if I can slide in a 0.21, then I'd do it up slightly until I can't get the 0.21 in, the 0.2 slides in ok, but a but sticky the 0.19 slides in with only a bit of resistance. By doing it this way you KNOW you don't have them too tight or too loose and don't really NEED to have a feel for the resistance required
NOTE: With tappets the gaps will open over time, with shims they close. So I'd set tappets on the minimum setting, shims on the largest!  ____________________ The purpose of life is to fight maturity. |
| Rockhopper |
 Rockhopper Trackday Trickster
| iooi |
 iooi Super Spammer
| Blue_SV650S |
 Posted: 21:52 - 24 Jun 2009 Post subject: |
| Swim41 |
| StevRS |
 StevRS Scooby Slapper
| Flash Gordon |
 Flash Gordon L Plate Warrior
| Thom |
 Thom World Chat Champion
 Posted: 12:52 - 26 Jun 2009 Post subject: |
by the way, rattley shims on a divvy are normal.
just incase you were checking for that reason.
I chanegd my shims to cure the rattling and simply made it worse by bringing them all intoo spec  ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
Previous Bikes: 1990 Honda NSR125 'Rothmans' (The smoking one), 1990 Suzuki GS500e 'Caf? fighter' (The loud one), 1987 Kawasaki GPX400r (The quick one), 1997 XJ600s Diversion (The reliable one), 2000 Kawasaki ER-5 (The spontaneously combustive one) |
| Swim41 |
The last post was made 17 years, 108 days ago. Instead of replying here, would creating a new thread be more useful? |
