| johnsmith222 |
 johnsmith222 World Chat Champion
| Darth |
 Darth World Chat Champion
 Posted: 16:04 - 25 Jun 2009 Post subject: |
I'm a cheapskate me - cant remember the last time i replaced a crush washer  ____________________ Harold_Shand wrote: I suppose it's like anything, you get your fingers burned when you start out, you learn from it and eventually become a complete arsehole about the whole thing. |
| fra-zzr |
 fra-zzr Spanner Monkey
| iooi |
 iooi Super Spammer
 Posted: 20:41 - 25 Jun 2009 Post subject: |
Remember washers can also be had from motor factors as well.
Little tip for removing filter. Wearing rubber gloves (kitchen type) improves grip no end  ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Raf |
 Raf Spanner Monkey
| Towton 1461 |
 Towton 1461 Scooby Slapper
 Posted: 02:38 - 26 Jun 2009 Post subject: |
Ask at your Kawasaki dealer or local m/c shop for an oil filter and a
sump plug washer. They'll usually give you one free, or for few pence.
(Last time they gave me two.)
Ideally, to remove/replace your filter, buying a 65mm oil filter cup
wrench off eBay, or somewhere, for the job is best.
I, however, am a skinflint. So I use a pair of plumber's pliers to
to loosen the filter, then tighten the new one up by hand and add
a little tweek with the pliers to make it snug.
By the way. Haynes' ZZR manual says it is necessary to remove
the oil cooler to remove the filter. This is not the case with
my 1996 bike, so it may not be with yours. Once I'd detached the
filter I found I could jiggle it out through the header pipes further
down. Reverse procedure to fit the new one.
As iooi says, rubber gloves help no end in gripping it. And
can protect against latent heat after warming the engine/oil up
prior to draining it.
Smear some fresh engine oil on the rubber seal on the new filter
before fitting it helps the seal.
Be careful not to over torque your sump plug and strip the threads. 20Nm is recommended. ____________________ This post is sponsored by QUILLIES LOZENGES. Suck QUILLIES for fast throat relief! |
| the grim reaper |
 the grim reaper World Chat Champion
 Posted: 11:52 - 26 Jun 2009 Post subject: |
You also want to fill the oil filter with fresh oil before fitting, that is assuming you don't have to turn it upside down to get it through the downpipes. The reason for this is that the oil pump pulls through the filter from the sump, so you have an oil pump running on nothing for a few seconds, which it will not like at all.
Incidentally, replace the washer and make sure you take the old on off, otherwise you get an incorrect torque reading when you retighten it. I once owned a Peugeot 406 that had four washers still on the sump plug ............... and a stripped sump plug thread. I had to drop the sump and get it re-tapped.
Cheers
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
The last post was made 17 years, 122 days ago. Instead of replying here, would creating a new thread be more useful? |
