ZZR Oil Change?
johnsmith222
PostPosted: 14:17 - 25 Jun 2009    Post subject: ZZR Oil Change? Reply with quote
Hi.
I'm going to do an oil change on my ZZR 600 but I do not know what I need.
Here's the list:
10w40 semi-synthetic oil (no problems here)
Sump plug crush washer (where do I get this and know I'm getting the right one?)
Oil filter (can I get this at halfords, and how do I know what one I need?)
also, do I need a special tool to change the oil filter?
Is there anything else that I need?
Thanks for your help.
PostPosted: 15:23 - 25 Jun 2009    Post subject: Reply with quote
Washers are meant to be replaced. Cheapskates get away without replacing them fairly often.
If the person who last changed the oil did it right then the filter should come off easily. If they over tightened it or didn't oil the O ring first then expect it to be harder (and you might well need something like a chain wrench).
Darth
PostPosted: 16:04 - 25 Jun 2009    Post subject: Reply with quote
I'm a cheapskate me - cant remember the last time i replaced a crush washer Mr. Green
fra-zzr
PostPosted: 20:08 - 25 Jun 2009    Post subject: Reply with quote
give the washer a little look over, but i didnt change mine for my last oil change. First place to look for a new one would be your local dealer (££) could probably call up a dealer and have it posted
04' Hyosung Comet Gt125
96' zzr600
iooi
PostPosted: 20:41 - 25 Jun 2009    Post subject: Reply with quote
Remember washers can also be had from motor factors as well.
Little tip for removing filter. Wearing rubber gloves (kitchen type) improves grip no end Thumbs Up
Raf
PostPosted: 20:53 - 25 Jun 2009    Post subject: Reply with quote
Just stick a screwdriver through the filter and it can be used as a handle. Works a treat.
CBR1100xx - BMW K1100 - BMW K100 - Triumph Sprint ST 955i - Suzuki GSX-R 600 - Suzuki DR 350 - Yamaha XV 750 - Honda CBR 600 FM - Yamaha XT 600 - Yamaha Rs 200 - Honda NSR 125
Towton 1461
PostPosted: 02:38 - 26 Jun 2009    Post subject: Reply with quote
Ask at your Kawasaki dealer or local m/c shop for an oil filter and a
sump plug washer. They'll usually give you one free, or for few pence.
(Last time they gave me two.)
Ideally, to remove/replace your filter, buying a 65mm oil filter cup
wrench off eBay, or somewhere, for the job is best.
I, however, am a skinflint. So I use a pair of plumber's pliers to
to loosen the filter, then tighten the new one up by hand and add
a little tweek with the pliers to make it snug.
By the way. Haynes' ZZR manual says it is necessary to remove
the oil cooler to remove the filter. This is not the case with
my 1996 bike, so it may not be with yours. Once I'd detached the
filter I found I could jiggle it out through the header pipes further
down. Reverse procedure to fit the new one.
As iooi says, rubber gloves help no end in gripping it. And
can protect against latent heat after warming the engine/oil up
prior to draining it.
Smear some fresh engine oil on the rubber seal on the new filter
before fitting it helps the seal.
Be careful not to over torque your sump plug and strip the threads. 20Nm is recommended.
This post is sponsored by QUILLIES LOZENGES. Suck QUILLIES for fast throat relief!
the grim reaper
PostPosted: 11:52 - 26 Jun 2009    Post subject: Reply with quote
You also want to fill the oil filter with fresh oil before fitting, that is assuming you don't have to turn it upside down to get it through the downpipes. The reason for this is that the oil pump pulls through the filter from the sump, so you have an oil pump running on nothing for a few seconds, which it will not like at all.
Incidentally, replace the washer and make sure you take the old on off, otherwise you get an incorrect torque reading when you retighten it. I once owned a Peugeot 406 that had four washers still on the sump plug ............... and a stripped sump plug thread. I had to drop the sump and get it re-tapped.
Grim
PostPosted: 13:28 - 26 Jun 2009    Post subject: Reply with quote
While I agree to fill the filter if you can, the oil pump pushes oil through the filter on most engines (and certainly the ZZR600).
The last post was made 17 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 63.01 Kb
