| _sketch_ |
 _sketch_ Scooby Slapper
| stirlinggaz |
 stirlinggaz World Chat Champion
 Posted: 14:03 - 25 Jun 2009 Post subject: |
hi,
stripping the carb is a fairly easy job.
theres a goode guide in here, written by Kickstart.
i dunno what make of carb you have but the basics are the same.
just remember what the settings are.
what clip the needle is on.
how many turns out the air/mixture screw is.
then give it a good clean.
you can buy aerosol carb cleaner cheaply.
one its been given a good clean, blow through all the jets etc, with an airline., making sure none of the jets are blocked.
you'll get an idea of the general state of the carb when you take the bowl off.
if its all stained with varnished fuel, then its probably best taking out the jets & cleaning them in some sort of solvent. (atomisers have tiny little holes around them, which can become clogged up with what looks like blobs of jelly! which is old fuel)
TYRES :duuno, i just buy them on-line & pay the £10-£20 to get them fitted.
EXPANSON CHAMBER: always found they do get extremely hot, but if your worried about it, do a plug chop.
good luck.
cheers,
GAZ |
| _sketch_ |
| Blue_SV650S |
 Blue_SV650S World Chat Champion
 Posted: 14:25 - 25 Jun 2009 Post subject: |
As well as having the carb apart, you might want to consider a new plug, where trials bikes spend a lot of time at low revs, the plugs can oil up making them run rough.
As for the heat thingy, the silencer bit is full of wadding, so isn't going to get as hot as the expansion chamber which is not. Its also closer to the motor.  ____________________ The purpose of life is to fight maturity. |
| stirlinggaz |
| _sketch_ |
| Blue_SV650S |
The last post was made 16 years, 234 days ago. Instead of replying here, would creating a new thread be more useful? |
