need help. got no drive
blutonium92
PostPosted: 23:32 - 25 Jun 2009    Post subject: need help. got no drive Reply with quote
Gota VFR400 NC30
went to pull away earlier just like any other of the million times i have and there was just nothing, just like as if i was in neutral.
But i put it in any gear and theres just nothing, no bite and it just rolls freely
It isnt the clutch cable and i can see the rod thats connected to the clutch cable still moves freely and theres no change in pressure with the clutch. its still springy and free.
any ideas what it is?
Now - Ducati 748, Laverda 650 Sport
Had- 56 Aprilia RS50, 03 Aprilia RS50, Hond VFR 400 NC30, Aprilia RS250, Suzuki SV650
PostPosted: 23:36 - 25 Jun 2009    Post subject: Reply with quote
Check your front sprocket is still attached and the splines are in good condition.
blutonium92
PostPosted: 08:35 - 26 Jun 2009    Post subject: Reply with quote
nothing to do with the sprockets mate.
PostPosted: 08:40 - 26 Jun 2009    Post subject: Reply with quote
Good of you to tell us that, but you didn't mention it in your original post!
Check that the clutch is working properly would be my next guess.
NSR Mick
PostPosted: 08:41 - 26 Jun 2009    Post subject: Reply with quote
One of the clutch plates may have disintegrated.
Clutch cover off to take a look.
Blue_SV650S
PostPosted: 08:46 - 26 Jun 2009    Post subject: Reply with quote
Silly question, but the linkage is still on the gear leaver? also does the gear leaver return to the central position or stay flopped down?
If it is not summin silly like that, then I'd say you have broken selector fork/s!! Sad
Or does it actually feel like it is engaging a gear, just not driving?
Have you tried putting it in 2nd, or 3rd?
the grim reaper
PostPosted: 12:09 - 26 Jun 2009    Post subject: Reply with quote
I would also try turning the engine off and putting it in gear, then push the bike forwards, does the rear wheel lock as the engine tries to turn over? If that's the case then your clutch and drive train are in one piece.
If the bike isn't actually going into gear, also check the splines on the gear rod and, as others have said, the gear linkage.
Grim
blutonium92
PostPosted: 18:48 - 26 Jun 2009    Post subject: Reply with quote
thanks for the replys.
Turns out it was the clutch. plates are warn.
Just strange how the clutch never slipped but went from being fine to not. normaly when they wear they start to slip.
The last post was made 17 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 56.47 Kb
