Honda CBR125R Highest speed possible help!
DannyE
PostPosted: 21:31 - 28 Jun 2009    Post subject: Honda CBR125R Highest speed possible help! Reply with quote
Just purchased a cbr 125 want to go in for the world speed record for 125, can anyone make any suggestions, so far a turbo and nos are the favoured options.
Burn rubber not soul Razz
Mudskipper
PostPosted: 21:58 - 28 Jun 2009    Post subject: Reply with quote
PostPosted: 22:36 - 28 Jun 2009    Post subject: Re: Honda CBR125R Highest speed possible help! Reply with quote
Shoulda bought a Mito mate... Rolling Eyes
simk2
PostPosted: 22:46 - 28 Jun 2009    Post subject: Reply with quote
You'll be wanting a supercharger instead of a turbo mate Laughing
I Really Need Parts For My Bike
stevo as b4
PostPosted: 23:27 - 28 Jun 2009    Post subject: Reply with quote
Get a copy of the test PB did a couple of years ago with a CBR125. They modded one, and changed the gearing mainly, to see if it could reach 100mph in ideal conditions. It got into the mid 80's i think?
The Original Muzza
PostPosted: 04:47 - 29 Jun 2009    Post subject: Reply with quote
If you can splice together two pink powerbands that would be optimal, failing that you might as well stick a banging donk on it in lieu of the powerbands.
PostPosted: 07:18 - 29 Jun 2009    Post subject: Reply with quote
That was slipstreaming a van too. Laughing
PostPosted: 07:19 - 29 Jun 2009    Post subject: Reply with quote
Cant see how it makes much difference which you use to be honest.
JAMSXR
PostPosted: 08:31 - 29 Jun 2009    Post subject: Reply with quote
There is a chap on here with an RS 50 which can do 75mph, maybe ask him for some advice..
PostPosted: 08:50 - 29 Jun 2009    Post subject: Reply with quote
You should have done your research before buying the bike, you will never get anywhere near any 125 record on a 4 stroke. There are stock 2t bikes you can buy with twice the power of the cbr.
nowhere.elysium
The Pork Lord
PostPosted: 10:23 - 29 Jun 2009    Post subject: Reply with quote
Sod him, there's a guy who's Piaggio X9 can do 78mph. You want one of them...
PostPosted: 11:07 - 29 Jun 2009    Post subject: Re: Honda CBR125R Highest speed possible help! Reply with quote
For a serious answer.
While you can probably get a bit more power from it, you are not going to gain much. A decently designed full exhaust (not just some bolt on can) might well move the torque further up the rev range and give you a bit more power. Possibly the same if you play around with different length trumpets on the carb. Skim the head and bring the compression up a bit and use supper unleaded fuel (but bear in mind that if you do this that using normal unleaded could lead to serious engine damage). Maybe clean the ports up a bit (find someone who knows what they are doing with gas flowing). Might get you a few more horsepower in total.
Simplest solution would be to source an engine from a CBR150. This is (I think) the engine that the CBR125 is based on, but not only has a higher capacity but also a 4 valve head. However this would be noticeably illegal on a learner licence.
While you could go silly and get a turbo or supercharger, you would really struggle to find one small enough, turbos are often said to be pains on single cylinder engines (too much change in the pressure that drives the turbo), and the cost would be way more than the bike is worth.
Roughly translating the above, forget it!
Mivv This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Mudskipper
PostPosted: 21:35 - 29 Jun 2009    Post subject: Re: Honda CBR125R Highest speed possible help! Reply with quote
Mivv wrote:
What do you think about a pipe? Smile
SPAM...SENSES...TINGLING
PostPosted: 23:00 - 29 Jun 2009    Post subject: Re: Honda CBR125R Highest speed possible help! Reply with quote
https://www.bikechatforums.com/files/spideyspam.jpg
PostPosted: 23:04 - 29 Jun 2009    Post subject: Reply with quote
BLUEX5 wrote:
Ride it out the back of a plane. You won't get the record but it'll make a fucking great darwin / an hero type moment.
A bit like at the beginning of the Cannonball run 2... Except that guy had a parachute! Wink
carlperkins00...
PostPosted: 20:49 - 30 Jun 2009    Post subject: Reply with quote
forget turbos, nos and superchargers.... you will need to go to that big hill in san fransisco and redline it.
Fnatic
PostPosted: 02:36 - 01 Jul 2009    Post subject: Reply with quote
For world speed records they make you go in both directions and then take an average. He'd be fucked on the way up.
Acemastr
PostPosted: 08:58 - 01 Jul 2009    Post subject: Reply with quote
my YBR (similar engine) redlines out at 76mph(indicated), you'd have to change the gearing to go much higher on a cbr surely?
2016 Toyota Tacoma Limited
carlperkins00...
PostPosted: 22:02 - 01 Jul 2009    Post subject: Reply with quote
HAHAHA!! Laughing
nightshaddow
PostPosted: 15:09 - 03 Jul 2009    Post subject: Reply with quote
you need more than turbos and nos to get that near the world record for a 125cc which i believe is 150+ mph and looks like a rocket on 2 wheels
you would need custom cooling custom gearbox new engine basically question is why would you want to i would say it is possible to push out enough power to top out over 100mph in theory but you would need probably £5000+ and some numbers of top engineers to make the parts you would need!!
why bother
Knacker
PostPosted: 01:52 - 05 Jul 2009    Post subject: Reply with quote
Just derestrict it put a k&n filter on it and run it on drag fuel it will piss 160 all day and that's just in 4th, from what iv heard they don't dare go higher through the box.
Previous: K1 GSXR 1000
tony2516
PostPosted: 17:22 - 23 Jul 2009    Post subject: CBR 125 can fast as you can Reply with quote
i ever seen Greece rider cbr 125 put DOHC 170 on his set since 4 years ago
his speed is over 180++
as sure
many europe used only 176 cc. SOHC for kit set
Sure, speed of CBR 125 can made fast as you satisfy
Fnatic
PostPosted: 17:42 - 23 Jul 2009    Post subject: Re: CBR 125 can fast as you can Reply with quote
as sure
Yes I'm sure that sequence of events took place.
Rolling Eyes
The last post was made 17 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 132.96 Kb
