Wiring Diagram
binge
Emo Kiddy
PostPosted: 19:17 - 29 Jun 2009    Post subject: Wiring Diagram Reply with quote
I need somebody to simplify a wiring harness for me.
I basically need to add a battery to my pit bike Hybrid because the output on the Reg/Rec is a bit high. And I also need a battery pack so I can run a Powervalve servo properly. As it needs to activate before the engine is started etc.
This is what I have in mind:
https://img.photobucket.com/albums/v358/binge/LOOM.jpg
I have no idea what the brown wire is for, I've been told its for "ignition". So not sure. I know it comes out of the reg/rec. Tested it on the Multimeter and barely 1 volt is coming from it when the bike is running.
Ben
finpos
PostPosted: 20:08 - 29 Jun 2009    Post subject: Reply with quote
Looks correct. You don't actually have to run the (black) wire from the reg/rec to the battery, you can earth it through the frame.
My <guess> about the brown wire is that it's a sense wire, in which case it's supposed to give feedback to the reg/rec about what the voltage is like out on the edges of the loom, not just at the battery terminals - it's possible there will be a slight drop. As such, it's usually connected to a live 12V somewhere down-loom of the ignition (key) switch, which is why it may have been described to you as such. If it is a sense wire, it really should be tied to a 12V supply somewhere.
f.
finpos
PostPosted: 20:12 - 29 Jun 2009    Post subject: Reply with quote
...also it's often more convenient to run the red wire from the reg/rec only as far as the unfused side of the fuse holder, or to the live side of the starter relay, depending on where all the components are. Just saves trailing wires back and forward.
f.
PostPosted: 20:13 - 29 Jun 2009    Post subject: Reply with quote
I fitted a honda rec to a Suzuki and it had an extra wire that had to be connected to switched live, can't remember the colour sorry.
I did find this on another site yesterday though:
binge
Emo Kiddy
PostPosted: 20:23 - 29 Jun 2009    Post subject: Reply with quote
So could that brown wire be why I am getting readings of 17/18 volts from the reg/rec at low RPM?
When I rev the bike, the voltage output drops to 12~
Ben
Blue_SV650S
f.
I agree, it is a sense wire! Thumbs Up It needs to go to a switched 12v source to help regulate the proper output.
But I don't agree that the black should go to the frame and not to the battery -ve.
binge
Emo Kiddy
PostPosted: 20:33 - 29 Jun 2009    Post subject: Reply with quote
Hmm, I might wire that brown wire to the back of the +tive on the headlight then. See what happens.
Ben
Blue_SV650S
PostPosted: 20:42 - 29 Jun 2009    Post subject: Reply with quote
Ben
As it is a 6 wire system (not the common 5 wire - that doesn't have the benefit of a remote sensor), I think you might well get away with having NO battery if the brown wire is connected.
Gotta be worth a try Thumbs Up
binge
Emo Kiddy
PostPosted: 20:47 - 29 Jun 2009    Post subject: Reply with quote
Hopefully it will work. The last thing I want to do is wire this Powervalve servo up and cook it by putting 18v through it. Sad
Blue_SV650S
PostPosted: 20:51 - 29 Jun 2009    Post subject: Reply with quote
You only need a tiddler of a battery if you end up using one to damp down the system, I know people that have a bugler alarm 12v battery purely to operate the power valve!! They only cost about a fiver too!! Wink
binge
Emo Kiddy
PostPosted: 20:54 - 29 Jun 2009    Post subject: Reply with quote
I've been looking at 12v powercells on ebay for about £10.
Thing is, Wont the Reg/Rec overcook that?
Ben
finpos
The sense function will only modify the output voltage of the regulator by about +/-1V according to load, and relatively slowly at that.
f.
finpos
PostPosted: 21:16 - 29 Jun 2009    Post subject: Reply with quote
I would have though you would get away with it, the reg/rec charges batteries pretty slowly (like a trickle charger). Depends entirely on the characteristics of the battery, but at any rate it should last a couple of years, which is pretty much what you'll get out of a cheap bike battery.
f.
Blue_SV650S
PostPosted: 21:21 - 29 Jun 2009    Post subject: Reply with quote
Ben
No, the reg/rec is there precisely to STOP it from getting fried!! Wink
Your most likely problem is the reg/rec will fry as it has to dissipate all that extra energy (when the battery is full, the reg rec has to do summin with the energy) ... but having the battery in there and always running with the lights on will minimise the risk.
If you run no battery, you are much more likely to kill the reg/rec as it has NOTHING to dissipate the energy (other than converting to heat).
binge
Emo Kiddy
PostPosted: 21:39 - 29 Jun 2009    Post subject: Reply with quote
Right seen.
I just have NO room to mount a conventional bike battery. At all.
What if I was to break one of the output wires from the stator?
I know with my pit bike stator, There were 2 wires from stator to Reg/Rec, Then 2 from Reg/Rec to loom.
But on certain race engines they only had 1 wire from the Stator to the Reg/Rec, Which was to power a single headlight for enduro riding etc.
The other wire from the stator was cut and earthed to the the stator plate. And the output to the reg/rec was so small that it wouldn't power my lights or horn properly until I re-connected the extra wire from the stator.
Ben
Blue_SV650S
PostPosted: 22:30 - 29 Jun 2009    Post subject: Reply with quote
You have 3 yellow wires, so have a 3 phase system. They are 3-phase as lead-acid batteries last longer when charged with pure DC. Having the 3 phases means once rectified, its a closer approximation to pure DC than say a single phase that pumps more out - picture it as riding the crest of 3 overlapping waves verses riding up the huge peeks and of a single - You are up and down less ...
Basically don't go chopping wires Wink
What you could do is add more load to the system so there are other things using up some of the energy. For example if it has a 35w headlight, put a larger wattage bulb in there (do watch it if your headlight wires are pathetic - might be best to double up so as not to melt them). You could also put a resistor in there somewhere ...
Perhaps consider putting a fan over the reg/rec to aid its cooling (and to use up a little bit more juice) ... re-locate it so it is in direct cool airflow ... perhaps put a computer heat-sink on it too???
As long as the reg/rec can keep suitably cool/get rid of the heat, you will be OK with a tiddy battery Thumbs Up
finpos
PostPosted: 22:53 - 29 Jun 2009    Post subject: Reply with quote
If you have no room for a battery, you can try replacing it with a big sod-off capacitor, which will have the same effect in taming your regulator output. Basically just connect the + and - terminals on the capacitor as you would a battery. Still big but not battery big.
You'll need one that's about 25,000mf to 50,000mf, rated for 20V or more. There's a couple going on ebay now for peanuts.
f.
binge
Emo Kiddy
PostPosted: 22:55 - 29 Jun 2009    Post subject: Reply with quote
Okay I'll have a look around.
Gonna have a go at connecting the brown wire to a 12v on the bike first to see how I get on.
The headlight is only bright (18v) when the bike is idling. Once I rev it, The voltage drops to 12v~ and the light dims.
Ben
The last post was made 17 years, 72 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 98.77 Kb
