| binge |
 binge Emo Kiddy
 Posted: 19:17 - 29 Jun 2009 Post subject: Wiring Diagram |
I need somebody to simplify a wiring harness for me.
I basically need to add a battery to my pit bike Hybrid because the output on the Reg/Rec is a bit high. And I also need a battery pack so I can run a Powervalve servo properly. As it needs to activate before the engine is started etc.
This is what I have in mind:
https://img.photobucket.com/albums/v358/binge/LOOM.jpg
I have no idea what the brown wire is for, I've been told its for "ignition". So not sure. I know it comes out of the reg/rec. Tested it on the Multimeter and barely 1 volt is coming from it when the bike is running.
Ben |
| finpos |
 finpos World Chat Champion
| finpos |
| Pete. |
 Pete. Super Spammer
 Posted: 20:13 - 29 Jun 2009 Post subject: |
I fitted a honda rec to a Suzuki and it had an extra wire that had to be connected to switched live, can't remember the colour sorry.
I did find this on another site yesterday though: ____________________ a.k.a 'Geri'
| binge |
 binge Emo Kiddy
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| binge |
 binge Emo Kiddy
| Blue_SV650S |
| binge |
 binge Emo Kiddy
 Posted: 20:47 - 29 Jun 2009 Post subject: |
Hopefully it will work. The last thing I want to do is wire this Powervalve servo up and cook it by putting 18v through it.  |
| Blue_SV650S |
| binge |
 binge Emo Kiddy
| finpos |
| finpos |
| Blue_SV650S |
| binge |
 binge Emo Kiddy
| Blue_SV650S |
 Posted: 22:30 - 29 Jun 2009 Post subject: |
You have 3 yellow wires, so have a 3 phase system. They are 3-phase as lead-acid batteries last longer when charged with pure DC. Having the 3 phases means once rectified, its a closer approximation to pure DC than say a single phase that pumps more out - picture it as riding the crest of 3 overlapping waves verses riding up the huge peeks and of a single - You are up and down less ...
Basically don't go chopping wires
What you could do is add more load to the system so there are other things using up some of the energy. For example if it has a 35w headlight, put a larger wattage bulb in there (do watch it if your headlight wires are pathetic - might be best to double up so as not to melt them). You could also put a resistor in there somewhere ...
Perhaps consider putting a fan over the reg/rec to aid its cooling (and to use up a little bit more juice) ... re-locate it so it is in direct cool airflow ... perhaps put a computer heat-sink on it too???
As long as the reg/rec can keep suitably cool/get rid of the heat, you will be OK with a tiddy battery  ____________________ The purpose of life is to fight maturity. |
| finpos |
| binge |
 binge Emo Kiddy
The last post was made 17 years, 73 days ago. Instead of replying here, would creating a new thread be more useful? |
