| stormofsilenc... |
 stormofsilenc... Derestricted Danger
 Posted: 13:13 - 28 Jun 2009 Post subject: NSR125R Bike Dies when changing from Nutral to In Gear |
Hi I’ll get strait to the point, but try and give you any information that may help.
My bike has been standing for a couple of months now, covered at my parents house. I’ve had this problem with the bike needing to be bump started as the battery goes flat after a while of being in suite. After bumping the bike I took it for a quick ride and pulled up at my destination (with no problems if anything the bike was running well). When I pulled up and turned off the engine, put the bike on it’s stand etc and was walking away the bikes alarm kicked in with its standard double beep.
When I returned to the machine, I pressed the key fob but the alarm did nothing, I took this as it being temperamental because of the very flat battery (this no noise of deactivation has happened before) I got on the bike, put it in neutral and tried to bump the bike into 2nd but the bike just didn’t run. I came to the conclusion because the battery was so flat the alarm/immobiliser got stuck on. So I put the bike somewhere safe and removed the battery, took it home and charged it.
Sorry if this is long winded I just want everything covered.
When I returned to the bike and re-inserted the battery the bike would then electric start etc. But again nothing from the alarm/immobiliser, nothing at all. I put it in neutral and started the bike – fine. But when I pulled the clutch in an put the bike in First the bike just dies, cuts out. I also tied this from N into Second. But again, the same results.
To cut the ending short, my brother and I (he being more mechanically minded) took the bike home and, altered the clutch because it was slightly loose, and tried with the alarm box removed, same results.
I’m really stumped on this one, is it the immobiliser? Remember the bike starts fine in Neutral.
Is it something else?
Any help is much appreciated as I’m a Student and money is something that evades me.
Cheers, Si
Honda NSR 125R 03 Red/White/Blue
Alarm is a Meta System Alarm - £300- worth (put on by bikes first owner) |
| Timmeh |
 Timmeh World Chat Champion
 Posted: 13:37 - 28 Jun 2009 Post subject: |
1. Get the bike's rear up in the air and make sure the rear wheel spins relatively freely when its in neutral with both the engine on and off. If not, the clutch is dragging.
2. Failing that, chances are the sidestand switch or wiring isn't working properly, and it thinks its always down. This will of course kill the ignition if you put it into gear.
HTH  ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| tshort2007 |
 tshort2007 Scooby Slapper
 Posted: 19:16 - 28 Jun 2009 Post subject: |
i get this with a lot with my AR, and my brothers NS. We find sometimes the clutch plates stick together when cold, so to release it, we hold the revs at around 2500, hold the front brake, hold the clutch handle in and then kick it into first. the shock frees the plates up, although they do stick for a few minuites until the oil warms slightly. once free, let off the throttle, and it should idle fine, although sometimes slightly under normal tickover speed.
Try it, saves pullin the engine apart! Good quality oil helps resolve it |
| Timmeh |
| stormofsilenc... |
| yen_powell |
| stormofsilenc... |
| stormofsilenc... |
| tone |
 tone Two Stroke Sniffer
 Posted: 23:23 - 28 Jun 2009 Post subject: |
You can bypass the clutch & side stand switches temperarly by joining the wires with a piece of spare wire across the connectors
I doubt the alarm/ immobiliser is at fault if you have removeed it properly as they are normally wired into the starter circuit at the solinoid & the bike wouldnt start at all if you had messed this up
Let us know how you get on  ____________________ Of all the things ive lost , i miss my mind the most |
| alains |
 alains World Chat Champion
| stormofsilenc... |
| dlatch |
 dlatch Nova Slayer
| Timmeh |
| stormofsilenc... |
| Timmeh |
 Posted: 12:21 - 30 Jun 2009 Post subject: |
Get yourself a wiring diagram (in haynes or off the net)
I've found one but it's in B&W which isn't very helpful.
Trace the wiring from pin 3 of the starter relay back towards the gearbox. Now find the neutral switch which will be a single wire coming out of the crankcase somewhere. Somewhere on the bike these two cables will meet. What you're looking for is a small diode with two wires coming out of it.
If the diode is not working, then the bike will always think it is in gear, regardless of whether the neutral light is on or not. A diode only conducts electricy one way, so if it is working you'll get continuity (using a multimeter) with the +ve on the side with the little stripe but none if you swop the test leads over. If you get continuity both times, or neither then you've found your answer!
As you've discounted everything else I hope this will be the solution.
| alains |
| stormofsilenc... |
| alains |
| stormofsilenc... |
 Posted: 16:30 - 30 Jun 2009 Post subject: |
Both of those codes are rectifiers not diodes.
So are they the same thing?
Not to bad tbh, like 20euro each so like what £30odd?...maybe more with the current state of the pound
Cheers |
| iooi |
 iooi Super Spammer
| Whosthedaddy |
 Whosthedaddy Super Spammer
| alains |
| stormofsilenc... |
 Posted: 21:54 - 30 Jun 2009 Post subject: |
| iooi wrote: | | stormofsilence wrote: | Sorry CHR15 we did remove the alarm, it took some pannel removing, but we pulled the plug out of it (with like 15 connectors inside) but I'm not sure if thats all of the alarm, is the immobilizer a separate box? buried somewhere else?
So are you saying that all you have done to remove the alarm is to take one connector off.....
The alarm will have been connected into the main harness, you will have to trace the wires back and find where connected and then find out which wires you need to join back together to totally remove the alarm..... |
Yeah, I know, but I dont want to cut the alarm out of the bike, besides the bike still starts fine in neutral so that doesn't explain that the alarm is the problem, I'm wanting to explore the cheaper diode(s) (possible malfunction) first, then If the finger can only be pointed at the alarm etc, it's an expense I'm going to have to find the cash for. It's still an issue and I knew that unplugging it wouldn't be the perfect answer, but I also hopped it would make it respond again, and at least go off when I tried to start the bike in neutral.
Cheers, I'm waiting on a Multi-Meter, so what exactly am I testing for? will the diodes have marked pins, what pins am i checking with what? I just dont want to get this wrong. When I find out some results, I'll let you know (hopefully tomorrow).
Cheers |
| alains |
| stormofsilenc... |
The last post was made 17 years, 112 days ago. Instead of replying here, would creating a new thread be more useful? |
