Aftermarket speedo = indicators constantly flashing
byke95
PostPosted: 19:37 - 30 Jun 2009    Post subject: [HELP!] Aftermarket speedo = indicators constantly flashing Reply with quote
Hi,
I've fitted an Acewell aftermarket speedo to my Honda 929 Fireblade. However, the indicator display is now constantly flashing (slighty dimmer than when indicator is switched on). Is there a way of stopping this 'pulse' when the indicator switch is in the 'off' position?
I'm getting desperate - MOT is due soon and this will be a failure. Mad
Hope this makes sense,
Thanks! Thumbs Up
Tristan.
PostPosted: 19:44 - 30 Jun 2009    Post subject: Reply with quote
Where is the wire for the Acewell indicator light spliced in, into the wire that would power the indicator lights on the stock clocks, or into the actual indicator wiring?
byke95
PostPosted: 19:47 - 30 Jun 2009    Post subject: Reply with quote
Into the indicator wiring - stock clocks didn't come with the bike..
Tristan.
PostPosted: 19:59 - 30 Jun 2009    Post subject: Reply with quote
Hmm, if it's significantly dimmer you may be able to stick a couple of resistors between the live indicator wires and the acewell to soak up the noise.
byke95
PostPosted: 20:25 - 30 Jun 2009    Post subject: Reply with quote
I'd say the constant flashing is quite bright, only slightly brighter when the indicator switch is on. Do you think resistors will still do the trick?
Noxious89123
PostPosted: 20:28 - 30 Jun 2009    Post subject: Reply with quote
Faulty switch? Might not be breaking the circuit completely?
Dunno, just throwing ideas out there...
Tristan.
PostPosted: 20:31 - 30 Jun 2009    Post subject: Reply with quote
You'd probably have to spend a while finding the right resistance that the clock lights stop flashing when it's switched off, but do visibly flash when it's meant to.
I'd look up the mot rules, you may get away without an indicator light, in which case disconnect it and tape over the LED.
Which acewell is it, and are the pulses on the clock when the indicators are off flash at the same frequency as the indicators themselves when theyre on.
(that was a really really shittily worded sentance btw Very Happy )
byke95
PostPosted: 20:54 - 30 Jun 2009    Post subject: Reply with quote
Makes perfect sense! Laughing
Sadly indicators (and high beam) are MOT requirements...
It's the Acewell ACE-39 series. Yup, the flash frequency is the same speed when switched off i.e. it's a constant when off or on, just a bit brighter when on.
Cheers for the ideas Noxious...the switch was working jst fine prior to the change of speedo.
Tristan.
PostPosted: 01:18 - 01 Jul 2009    Post subject: Reply with quote
and when the indicators are on the clock light flashes at the same time/rate? (Just trying to work out if the rogue pulses are caused by the bikes relay or an internal relay in the acewell)
got access to a multimeter? check the voltage from where the acewell wire picks up and an earth point whith the indicator both on and off
The last post was made 17 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.59 - MySQL Queries: 14 - Page Size: 59.87 Kb
