Internet explorer
Scouse
PostPosted: 11:56 - 07 Jun 2004    Post subject: Internet explorer Reply with quote
Right there's a small problem I'm having here with the internet explorer. After I click in the address box to enter a different site, I get an error message as soon as I press any key and the explorer window closes. At the minute the only way I can access different sites is to write the address in the Google toolbar search box, and then copy and paste it into the address part. This though, is pretty annoying.
Anybody know a solution? Confused
Mattastic
PostPosted: 11:59 - 07 Jun 2004    Post subject: Reply with quote
Have you run Adaware and your virus checker? This could be one problem. I had one the other week that no matter what address I typed I got re-directed to a porn site!
Too skint to buy a bike Sad
Scouse
PostPosted: 12:18 - 07 Jun 2004    Post subject: Reply with quote
Yes I did a spyware scan and it found nothing. Confused
PostPosted: 12:19 - 07 Jun 2004    Post subject: Reply with quote
what does the error read?
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
Scouse
PostPosted: 12:23 - 07 Jun 2004    Post subject: Reply with quote
IEXPLORE caused an invalid page fault in
module WININET.DLL at 016f:762838fe.
Registers:
EAX=00000000 CS=016f EIP=762838fe EFLGS=00010246
EBX=843d0600 SS=0177 ESP=03d2ed54 EBP=03d2ed7c
ECX=ffffffff DS=0177 ESI=00000044 FS=5287
EDX=0000001f ES=0177 EDI=845d0600 GS=0000
Bytes at CS:EIP:
f2 ae f7 d1 49 8d 44 0a 01 89 45 08 e9 33 fe ff
Stack dump:
00492e00 843d0600 00004128 00000000 76292558 00013600 00492e00 00421ab8 00004128 00000000 03d2edb0 762924fc 843d0600 03d2edbc 03d2fe44 00000000
Frost
PostPosted: 12:27 - 07 Jun 2004    Post subject: Reply with quote
Re-install IE from the XP disk?
Scouse
PostPosted: 12:31 - 07 Jun 2004    Post subject: Reply with quote
Right well the thing is, for a start it's windows 98 and I've checked the disc but cannot see the IE setup/installer anywhere. Sad I tried looking in the control panel for it so I could re-install it but either I am blind or the dumb blonde theory may really work. Confused
ZZ-Rse
PostPosted: 12:35 - 07 Jun 2004    Post subject: Reply with quote
Firefox
/nod
Mr Pants!
I Karma
PostPosted: 12:44 - 07 Jun 2004    Post subject: Reply with quote
Control Panel, Add/Remove programs, then select Windows Components. Click on IE and I think it can run a repair. Should sort it out.
Cool
Mr Pants! (Alex or Al)
Its better to burn out, than to fade away....
Scouse
PostPosted: 12:56 - 07 Jun 2004    Post subject: Reply with quote
Right the problem is sorted, downloaded Firefox and it is working fine now. Thanks for the help. Very Happy Thumbs Up
tgabber
PostPosted: 15:32 - 07 Jun 2004    Post subject: Reply with quote
A hint for anyone with similar problems next time is to check whether you have any third-party browser extensions causing problems. There is a setting in IE to disable them.
In IE, Go to Tools -> Internet Options -> Advanced and then untick the box that says 'Enable third-party browser extensions'
If IE won't even start you can also access this setting via Start Menu -> Settings -> Control Panels -> Internet Options
This is an all or nothing setting, the current version of IE does not allow you to selectively switch off and on individual extensions (also called Browser Helper Objects or BHOs). You can however get third-party programs to do this.
Of course, problems like this can be avoided entirely if you use a better browser like Opera for instance... Wink
"It's all about dislocating expectation"
Kawasaki KMX125 -> Aprilia RS125 -> Kawasaki ZZR600
The last post was made 22 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 66.98 Kb
