Chain lube & grease remover recommendations?
Gazanimal
PostPosted: 00:15 - 08 Jun 2004    Post subject: Chain lube & grease remover recommendations? Reply with quote
I'm in need of purchasing some chain lube/oil for my CBR 600 as well as a nice cleaning product that will remove some chain spray-off from the undertray.
Some of the grease/much/chain cack has found itself on my side fairing near the pillion seat & is a bugger to remove as it sticks like sh*t to the proverbial blanket.
Some good recommendations please?
Auto-glym cleaning kit any good?
Scottoil for the chain perhaps?
Thanks in advance guys. Wink
McJamweasel
BCF Junkie
PostPosted: 00:16 - 08 Jun 2004    Post subject: Reply with quote
WD40 Thumbs Up
Gazanimal
PostPosted: 00:25 - 08 Jun 2004    Post subject: Reply with quote
Thanks for the suggestion McJamweasel.
A friend didn't recommend WD40 on an o-ring chain as he said it might make the rings go brittle,also he mentioned that WD40 isn't the best thing to use on plastic bodywork as it can fade it over time?
Thoughts please. Confused
McJamweasel
BCF Junkie
PostPosted: 00:30 - 08 Jun 2004    Post subject: Reply with quote
Sorry - skim read.
WD40 degreaser - I use Yoshi-moto 'kin good chain lube. Thumbs Up
craigT19
Jolly Green Giant
PostPosted: 11:46 - 08 Jun 2004    Post subject: Reply with quote
i use a scott oiler for the chain lubing
and the same yoshi motot stuff as mcjam...altho my "muc-off" kit is also very good.
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
carvell
Scuttler
PostPosted: 12:04 - 08 Jun 2004    Post subject: Reply with quote
I used parafin (you can also use petrol) and a brush to get rid of the grease on there.
To lube it I use "Silkoline Chain Gel".
Yamaha TDM 850
dibbster
PostPosted: 13:57 - 09 Jun 2004    Post subject: Reply with quote
I use Castrol Chain Wax. Works a treat!
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
Lee_367
PostPosted: 16:52 - 09 Jun 2004    Post subject: Reply with quote
i use gunk as a degreaser, removes anything Karma
?It?s mercy, compassion, and forgiveness I lack?not rationality.?
Zx6man
PostPosted: 16:59 - 09 Jun 2004    Post subject: Reply with quote
To clean chain use paraffin
Castrol chain wax for lube (make sure chain is clean first tho, as it can turn to a grinding paste if not)
To clean chainlube off plastics use mr sheen, saves polishing after, works as well as wd40 and cheaper.
Never use gunk on chains, will remove the oil from inside the chains o rings, (assuming its an o ring chain of course)
yohomiesmelly...
PostPosted: 19:09 - 09 Jun 2004    Post subject: Reply with quote
I find that auto glyms oil degreaser along with fuchs muck-off works well as a combination as long as you leave it for a good 2 mins and wash off with hot soapy water.
If you want to go to the extreme then go for something like gunk it should cut through anything but don't take it near alloys as i think it has bad effects on it.
True Blue
PostPosted: 21:52 - 09 Jun 2004    Post subject: Reply with quote
Wurth High Performance Dry Chain Lube 500ml £6.98 is the one that won the MCN product test thingy. Thumbs Up
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
jay12329
Dr. Evil
PostPosted: 18:55 - 10 Jun 2004    Post subject: Reply with quote
I use Muco bike de-greeser, and castrol chain wax.
I have muco doing its work at the mo, so ill have a nicely lubed chain for tomorrow!
J
The last post was made 22 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.33 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 72.24 Kb
