Honda CBR stalling problem
ogx
PostPosted: 21:08 - 09 Jul 2009    Post subject: Honda CBR stalling problem Reply with quote
Just bought a little Honda CBR 125 as my first bike to learn on and day 2 of ownership (its a 2007 model with 5k miles) it started to judder when riding before engine cutting out. Didnt start the first time it happened even using the choke so had to bump start it however within 20mins of normal riding after it happened it cut again and when i tried to start it again it worked but as soon as 1st gear was selected it cut out. Had to put the choke on to get it going again. Any ideas? Sad
The Artist
PostPosted: 22:14 - 09 Jul 2009    Post subject: Reply with quote
No offence but it is probably a combination of you and some slightly sticky clutch plates and an engine that needs a service.
Try revving it very slightly before you select 1st and it should stay running.
ZZR-Souls
PostPosted: 22:53 - 09 Jul 2009    Post subject: Reply with quote
Try cleaning the side stand switch. The side stand has a switch that prevents you riding with the stand down. If the switch is dodgy it will cut the engine when any gear is selected. Also could be a weak spring that holds the sidestand up allowing the switch to be activated inadvertantly.
JOIN IN THE BIGGEST RIDE-OUT OF 2007 here
ogx
PostPosted: 17:33 - 10 Jul 2009    Post subject: Reply with quote
got it sorted. Made a few small slots on the rubber washer around the fuel cap cover and its solved it Very Happy so far anyways...
ash-2009
PostPosted: 14:11 - 11 Jul 2009    Post subject: Reply with quote
my honda xr 125 done the exact same thing look for my old post mine sorted its self out all i done was put a bit of red-ex carb cleaner through the tank with a full tank of petrol and took her for a ride been ok since touch wood Wink
Jeansy001
PostPosted: 17:49 - 26 Jul 2009    Post subject: Reply with quote
When i owned a CBR 125 I had a problem that sounds similar. The carburetor hadn't been cleaned out for a while so it was full of gunk and there wasn't enough fuel getting into the engine, carburetors are a pain to sort so best take it to a garage if you haven't got a diagnosis yet.
also check your fuel pipes and make sure there's no splits or anything, make sure your air filter is clean aswell
The last post was made 16 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 47.07 Kb
