Clutch plate notch.
Coxyzxr
PostPosted: 20:55 - 10 Jul 2009    Post subject: Clutch plate notch. Reply with quote
Rebuilding the clutch on the GS125. The friction plates have a notch cut out on one of the tabs of EACH friction plate.
Any reason for that? Ie they need to go in a line or altenating degrees for each plate?
I've doctored and attached a picture up to indicate what I mean.
Need to get it right as I'm about to gasket the side cover up after this.
Kind regards.
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
PostPosted: 21:26 - 10 Jul 2009    Post subject: Reply with quote
No reason I can think of. Might be a jig locating notch as part of the manufacturing process.
Coxyzxr
PostPosted: 22:03 - 10 Jul 2009    Post subject: Reply with quote
Cool stuff, I'll go with that.
Many thanks.
Coxyzxr
PostPosted: 22:04 - 10 Jul 2009    Post subject: Reply with quote
Vincent wrote:
Yes.
Care to elaborate? Laughing
Coxyzxr
PostPosted: 22:11 - 10 Jul 2009    Post subject: Reply with quote
Vincent wrote:
I've never even thought why before but it could be so that the lines on the plates don't all match.
Could be yes, good point.
Kind regards.
PostPosted: 22:22 - 10 Jul 2009    Post subject: Reply with quote
Vincent wrote:
I've never even thought why it would stop them sticking together before but it could be that, if placed alternately, the lines on the plates don't all match I guess. Thus making it easier for them to come apart.
But there are steel ones inbetween them all.
PostPosted: 23:25 - 10 Jul 2009    Post subject: Reply with quote
For what it's worth. The last clutch I did had them and I lined them all up in the same slot. Seems to work fine.
Frost
PostPosted: 13:13 - 11 Jul 2009    Post subject: Reply with quote
Last clutch i did had those notches on all plates.
The clutch basket had 3 notches on it, the plates had to be alternately aligned to each.
Coxyzxr
PostPosted: 14:18 - 11 Jul 2009    Post subject: Reply with quote
Thanks, I did have a nose on the basket but couldn't see anything. I'll check it out further when at home later.
ZZR-Souls
PostPosted: 22:39 - 11 Jul 2009    Post subject: Reply with quote
If all the nothes are in the same place wouldn't it cause a balance problem? If I saw that I'd tend to space the notches evenly around the basket. Remember, these things spin at the same speed as the engine, fookin fast.
JOIN IN THE BIGGEST RIDE-OUT OF 2007 here
PostPosted: 09:04 - 12 Jul 2009    Post subject: Reply with quote
Typically they will spin at 1/4 to 1/3 engine speed.
The last post was made 17 years, 89 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 105.13 Kb
