nsr125 flat spot at full throttle
buddy
PostPosted: 12:13 - 11 Jul 2009    Post subject: nsr125 flat spot at full throttle Reply with quote
hey all, my nsr125 flat spot at full throttle
yes it has been upjetted to 42, 65 and 138, does it need a bigger main jet?
When this baby hits 88 miles per hour... you're gonna see some serious shit.
PostPosted: 12:42 - 11 Jul 2009    Post subject: Reply with quote
What revs is the flat spot?
spitfire123
PostPosted: 14:39 - 11 Jul 2009    Post subject: Reply with quote
for him between 2k and 12k LOL.
You won't be able to eat my dust......As it'll settle before you get there.
alains
PostPosted: 15:09 - 11 Jul 2009    Post subject: Reply with quote
it needs a compression test
buddy
PostPosted: 17:05 - 11 Jul 2009    Post subject: Reply with quote
maybe with someone of your weight on it Laughing
the flat spot is bad around 4-7k but isnt that great at full throttle through the entire rev range,
it sort of gets to half throttle and then dosent get any more powerful after half throttle(if that makes sence)
yeah the problem might be compression, its due for a full rebuild, can i just put oversize piston and rings in it instead of buying a shiny new expensive cylinder?
PostPosted: 17:48 - 11 Jul 2009    Post subject: Reply with quote
Full throttle at low revs with a slide carb (ie, what is on most 2 strokes) is useless. The engine isn't turning over quickly enough for the carb to work properly.
With the barrel really you need to know how worn it is (if at all, the plating shouldn't wear much) and then find out what piston and rings you need.
buddy
PostPosted: 08:24 - 13 Jul 2009    Post subject: Reply with quote
yeah i kinda knew it was characteristic of a 2 stroke but it does seem particuluy bad
its almost like it feels like it pulls less when ya open it right up than at half throttle
PostPosted: 09:45 - 13 Jul 2009    Post subject: Reply with quote
It is a characteristic of slide carbs.
At low revs if you were on full throttle and backed off I would expect it to gain power, but not at high revs.
As Alains suggests, do a compression check. Easy to do, and could reveal a problem.
spitfire123
PostPosted: 11:07 - 13 Jul 2009    Post subject: Reply with quote
its has done over 26k or somthing around that.
the cilinder WILL need changing by this time. Laughing
The last post was made 17 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 62.37 Kb
