| RSmark |
 RSmark Derestricted Danger
| Burnzy1989 |
 Burnzy1989 Nitrous Nuisance
| stirlinggaz |
 stirlinggaz World Chat Champion
| bladerunner |
 bladerunner World Chat Champion
| RSmark |
| Kickstart |
 Kickstart The Oracle
 Posted: 11:36 - 13 Jul 2009 Post subject: |
As above with the plug. The number with NGK plugs is the heat range. The higher the number the colder the plugs (basically reduced / increased insulation to change the amount of heat that escapes via the plug). Higher numbers will foul up more easily, while lower numbers will overheat and blister. Aprilia listed an 8 for the restricted bike and a 10 for the full power bike.
As to it running rich, you will probably need to richen the mixture up to go with the Arrow pipe. However running too rich will lose you power. Running too lean will also lose you power, but also risk a seizure. Hence people tend to go slightly rich for safeties sake (and a rich mixture will foul the plug more quickly).
| RSmark |
 Posted: 11:42 - 13 Jul 2009 Post subject: |
Yeh i think your right also it could be the fact that im used to starting up my 1st bike (which was a 4 stroke) and just letting it tick over before riding to work so i will have to clean up the spark plug or get a new one methinks. Cheers keith nice one mate if the spark plug dont work then il be back on here for help lol  ____________________ Well into my cars and bikes although i know alot more about cars than bikes. Just bought an RS125 but have no experience with aprilia's, i'm used to 4 stroke honda 125.. |
| tutton |
 tutton World Chat Champion
 Posted: 13:32 - 13 Jul 2009 Post subject: |
Not hugely relevent to the original post, but with the RS125's best way is to start em and ride em keeping them under around 5k until the temp lcd shows around 65ish, thats when i used to start using the powervalve, Make sure your using good quality 2stroke oil, similar to Castrol TTS Power1 or similar.
Lovely handling little bikes, i may go back to one again  ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
Current: '02 ZX636 A1P '51 CCM R30 |
The last post was made 17 years, 66 days ago. Instead of replying here, would creating a new thread be more useful? |
