What do you do when the throttle cable snaps?
Coxyzxr
PostPosted: 09:38 - 12 Jul 2009    Post subject: What do you do when the throttle cable snaps? Reply with quote
10 miles from home, 24 miles from work.
Do you;
A: Increase the idle speed and ride that home?
B: Wrap the broken cable around your finger like a cheese wire and tug that?
C: Phone road side rescue?
I opted for B. Almost killed my finger and it made juggling the throttle cable and front brake quite precarious but got me the 10 miles home.
A. was no good, speed was too low and interesting looks from passes by when you had to stop for give way, clutch in and revs shot up to 6k permanantly. Didn't do the temp any good either.
C: Just no.
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
Bikeless
PostPosted: 09:41 - 12 Jul 2009    Post subject: Reply with quote
You forgot D:Phone mate with van, Thumbs Up
MaybeGuy
PostPosted: 09:59 - 12 Jul 2009    Post subject: Reply with quote
i cranked my idle speed up to 10k on the GSXR. still meant that i got home at 60mph and couldnt accelerate at all.
S1KE
PostPosted: 10:23 - 12 Jul 2009    Post subject: Reply with quote
This happened on my zxr, I just turned up the idle speed as far as it would go and rode it home at 50mph !
Mike
random twat!
* xbox live mickeyc26
* zx6r b1h 2004 GREEN !
Coxyzxr
PostPosted: 10:43 - 12 Jul 2009    Post subject: Reply with quote
What a stich, first time it's happend to me.
Incidently I already replaced the old frayed throttle cable with a spare one some time ago as frayed one didn't looked like it would do the distance(bare in mind it already served me 6 months of first having the bike) and it's the perfectly good replacement one that snaps on me!
Finglonga
PostPosted: 11:23 - 12 Jul 2009    Post subject: Reply with quote
Could be routed wrong causing it to rub.
Andy Sez....
F.Y.Y.F.F.
Clanger
Stirrer
PostPosted: 11:27 - 12 Jul 2009    Post subject: Reply with quote
Start pushing the bike, or ring a friend with a van. Or ring the AA since I'm a member, or ring 0870 7500607 (the motoribke recovery people).
Coxyzxr
PostPosted: 12:53 - 12 Jul 2009    Post subject: Reply with quote
Nah it all seems good, it snapped the 'fly' off the end.
PostPosted: 15:16 - 12 Jul 2009    Post subject: Reply with quote
Hook the choke cable to the throttle bodies for 'lawnmower control' Smile
Coxyzxr
PostPosted: 16:32 - 12 Jul 2009    Post subject: Reply with quote
Fisty
PostPosted: 17:13 - 12 Jul 2009    Post subject: Reply with quote
I did over 40 miles at 35mph when my throttle cable snapped. I used the Idle speed method. Worked quite well TBH, still got home quicker than waiting for the AA to come!
Fatter and faster than Fret
yen_powell
PostPosted: 20:13 - 12 Jul 2009    Post subject: Reply with quote
I swapped the push cable over at one end when my FJ cable snapped. It worked, but you had to twist the throttle the wrong way to rev the bike. Got me the 50 miles home, but a bit scary when changing down the gears.
XT1200Z and a DR350 in bits
Coxyzxr
PostPosted: 21:17 - 12 Jul 2009    Post subject: Reply with quote
Good bodge. Unfortunately already had removed the push cable on mine. TBH if I had put more thought into it I'm sure I could of come up with something sweet bodge wise.
I remember a while back the coolant pipe that runs off the main pipe to route into the carbs split on the motorway, pissing water out and up my leg.
Had no cutters to cut some hose of the tank breather and plumb that in, only a few allen keys. Forced the biggest allen key I had into the hose to block it, managed to get me to work where I could sort it properly with some scissors.
Roadside bodges, nothing like it!
TUG
PostPosted: 23:08 - 12 Jul 2009    Post subject: Reply with quote
Ride home useing choke cable.
Haz ER-5, innit!
PostPosted: 00:37 - 13 Jul 2009    Post subject: Reply with quote
Attach the cable outer to the fork stanchion or top yoke using a cable tie or jubilee clip.
Attach the inner to the outside of the throttle twist grip with another cable tie or jubilee clip.
OR
Get the Hein Gericke cable repair kit out from under the saddle and repair the cable.
Ride home normally.
Drifterwannab
PostPosted: 09:51 - 13 Jul 2009    Post subject: Reply with quote
not directly the same but my clutch went on my rs125 many years ago, and i had to ride it home 10 mile through urban roads - the method.. clutchless gearchanges up and down... not too bad on the RS - but when got close to traffic lights etc get down to slow speed then kill it on the kill switch, to ride off again ride it on the starter button elecy go cart stylee! was fun and luckily enough didnt damage anything Mr. Green
The last post was made 17 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.66 - MySQL Queries: 13 - Page Size: 94.5 Kb
