bike keeps wobbling about, also carb is leaking
bradderz
PostPosted: 10:22 - 13 Jul 2009    Post subject: bike keeps wobbling about, also carb is leaking Reply with quote
hi i have a yamaha sr125. it has recently started to loose control abit, it doesn't feel stable, especially round the bends. also i can feel when i am slowing down, the bike slightly jolts, like the brake has been slightly pulled, then let go, then pulled.... i would like to know if anyone has an ideas about this problem?
the other problem i have is that the carb is leaking f**k loads of petrol. and i was told it might have something to do with the float height or float pin, not sure, definitely heard the word float! anyway i have no idea of the assembly of the carb, so would anyone give me some instruction please to what to do, maybe even a diagram of it.
thanks
Suntan Sid
PostPosted: 13:30 - 13 Jul 2009    Post subject: Reply with quote
Could be that your leaking carb is dumping petrol onto your back tyre, I had this problem a long time ago.
It was just dirt in the float bowl, a sharp tap on the float bowl might dislodge the dirt, it worked for me, stopped the leak, and cured my slippery back tyre!
Finglonga
PostPosted: 13:44 - 13 Jul 2009    Post subject: Reply with quote
Check your tyre pressures and Google Needle float to get an idea what your looking for.
Andy Sez....
F.Y.Y.F.F.
bradderz
PostPosted: 15:52 - 15 Jul 2009    Post subject: Reply with quote
hi i tried giving it a couple of taps, didnt work, gave it quite a few taps and bangs, still did not work.
any ideas anyone?
wizzzard
PostPosted: 16:06 - 15 Jul 2009    Post subject: Reply with quote
Handling wise :
Grab hold of each wheel and give it a good ragging side to side and check for any free play. If it they wobble excesively then new bearings are on the cards. Grab the front brake and with hands on handlebars rock the bike back and forth to see if your headrace bearings are buggered and loose.
Carb wise:
They are not that complicated and it wouldnt hurt to take it off and strip it to have a look.
I've had a couple of sr's and I think I may have a manual saved to my computer. If I can find it when I get in I'll pm you.
PostPosted: 17:42 - 15 Jul 2009    Post subject: Re: bike keeps wobbling about, also carb is leaking Reply with quote
I'm surprised nobody has suggested a warped brake disc yet Confused
stirlinggaz
PostPosted: 20:24 - 15 Jul 2009    Post subject: Reply with quote
Hi,
this is always a good thing to read, if you want to know about carbs
https://www.bikechatforums.com/viewtopic.php?t=17124
might be a different make &/or type but the basics will be the same, especially the carb float height & needle stuff.
cheers,
GAZ
bradderz
PostPosted: 10:03 - 16 Jul 2009    Post subject: Reply with quote
ok looks like it mite be the bearings, but having some trouble gettin the bearings out. is there some sort of tool i use to get it out?
Majik
PostPosted: 15:13 - 16 Jul 2009    Post subject: Reply with quote
Birmingham 5/8ths adjuster
www.suzukigoose.co.uk
bradderz
PostPosted: 16:04 - 19 Jul 2009    Post subject: Reply with quote
what is that?
The last post was made 17 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 63.02 Kb
