Nc29 name that part!
Azonicben
PostPosted: 11:42 - 14 Jul 2009    Post subject: Nc29 name that part! Reply with quote
Just had the front end off the cbr to replace some crash damaged parts.
Coming out from the behind the clocks there was a three pin connector ending in a big gooey blob of old electrical tape!
I've unpicked it and enclosed was a small Pcb, I can't figure out what is is or what it does. The bike doesn't really seem to care if it's connected or not. Runs and revs fine all lights, alarm and everything appears to work fine without.
Haynes manual seems to have vanished in the recent move and the iPhone doesn't like the 200page online PDFs available.
What is it? Cookies for helpfulness Thumbs Up
https://s160.photobucket.com/albums/t198/azonicben/8e6e9ffd.jpg
binge
Emo Kiddy
PostPosted: 11:54 - 14 Jul 2009    Post subject: Reply with quote
IIRC its something to do with the 180kph speed restrictor. I know there was a way of derestricting them by looping 2 of the wires. Dont quote me on that though.
Ben
Azonicben
PostPosted: 12:00 - 14 Jul 2009    Post subject: Reply with quote
That would make sense, although I've already got a mechanical kph to mph converter on so it's never going to reach 180mph effectivly removing the restriction anyway.
Reckon it'll do any damage without it? Or should I just wrap it back up and poke it back behind the clocks?
binge
Emo Kiddy
PostPosted: 18:09 - 14 Jul 2009    Post subject: Reply with quote
I'd just leave it out to be honest mate. I think it's been removed from the clocks anyway by the looks of it.
Ben
Azonicben
PostPosted: 19:31 - 14 Jul 2009    Post subject: Reply with quote
From one benji to another, cheers matey!
Btw still want to pinch the pit for an hour, been looking at the masii's from j&s vey very tempted. You got the tzr lump working yet?
finpos
PostPosted: 19:38 - 14 Jul 2009    Post subject: Reply with quote
Detector for the speed restrictor, The blue thing with the two black blobs is an optical switch, when a bit of metal attached to the speedo needle goes between the black bits it switches on the restriction. Obviously, with it being outside the clocks, that won't happen. If you cut it off, the ECU will know it's not there, so best leave it dangling.
f.
Bikeless
PostPosted: 20:09 - 14 Jul 2009    Post subject: Reply with quote
f.
That's what i thought,if you disconnect it,it will only fire on 2 cylinders.
Blue_SV650S
PostPosted: 21:32 - 14 Jul 2009    Post subject: Reply with quote
Yep, as mentioned above, you take it of and the CDI will complain!! ... you now have 2 options ... leave it dangling (as above) or you can fit an appropriate resistor to fool the CDI/ECU its still connected ... Thumbs Up
The last post was made 17 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 55.66 Kb
