speedo stopped working
damz
PostPosted: 02:29 - 14 Jul 2009    Post subject: speedo stopped working Reply with quote
on my way to work my speedo stopped working, thought it may have been my kmph/mph converter that may had broke.
however iv'e removed it so i can at least get a kmpmh reading however that doesnt work now.
any idea's what it may be?
Current Bikes RVF400 - 94
Cars: RX7 FD, Eunos Roadster
PostPosted: 08:33 - 14 Jul 2009    Post subject: Reply with quote
Speedo drive.
iooi
PostPosted: 08:56 - 14 Jul 2009    Post subject: Reply with quote
Cable ??
damz
PostPosted: 14:48 - 14 Jul 2009    Post subject: Reply with quote
where can one get a speedo drive? checked ebay and david silvers my two usual spots but they dont have it listed.
Sosha
PostPosted: 14:58 - 14 Jul 2009    Post subject: Reply with quote
If it's the sort where the cable rotates, it's worth checking that cable is still in one bit. they break eventually.
Eliminating dynamic range since 1999
damz
PostPosted: 15:10 - 14 Jul 2009    Post subject: Reply with quote
theres no cable on the wheel, it just leads intowards the inside of the bike
PostPosted: 16:38 - 14 Jul 2009    Post subject: Reply with quote
DSS should list it, although it may not be called that on their site. Give them a ring?
iooi
PostPosted: 17:45 - 14 Jul 2009    Post subject: Reply with quote
Some bikes have the cable coming from the gearbox final drive.
Pull the inner cable out. If there is no suqare end, then its bust. You just need to follow the cable down to see where its driving from.
damz
PostPosted: 01:03 - 15 Jul 2009    Post subject: Reply with quote
i suspect it is the cable that is broken. i removed the speedo drive and nylon nut, the nut rotates and the small block on the other side of the drive rotates as well, however the end of the cable does not rotate.
ordered a new drive and speedo just incase, honda dealership were wanting £93 and wait till end of august for the drive so bought a used one from a vfr which is the same for a tenner and ordered a few bits and bobs from david silvers.
hopefully they'll arrive in a few days.
The last post was made 17 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 58.76 Kb
