Been awhile but got a problem
 Topic moved: from General Bike Chat to The Workshop by Korn (8 Jun 2004 - 19:43)
minesweeper
Whoah there!
PostPosted: 19:18 - 08 Jun 2004    Post subject: Been awhile but got a problem Reply with quote
Long time no see all
Just finished dusting my rvf after its winter slumber, fixed a few problems but got one left i need alittle help with.
Despite having power for the lights, indicators and everything else the ignition doesnt appear to work, doesnt make any noice what so ever when the buttons pressed, the battery has loads of charge so im guessing it might be the cdi unit? am i way off the mark? ideas.....
Matt
PostPosted: 19:25 - 08 Jun 2004    Post subject: Reply with quote
Most likely the starter relay. You might be able to short this out to get the engine cranking over (but not on all, and be careful when doing it). Also press the starter button and while it is held down tap the relay with the handle of a screw driver which might shock it into working again.
Demonic69
The Pink Rhino
PostPosted: 19:37 - 08 Jun 2004    Post subject: Reply with quote
Try bumping the bike. If it runs that's one less thing to worry about. My RF did the same and the ignition worked fine after.
Also check the side-stand light is on when it's down Wink
Back on a Blade. Just feels so right.
TiN
Pocket Tin
PostPosted: 23:26 - 08 Jun 2004    Post subject: Reply with quote
Kill-switch? Rolling Eyes
Could possibly be the reg/rec. As Demonic has suggested, try bump starting the bike.
TiN
dotgems.net
The last post was made 22 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 16 - Page Size: 40.47 Kb
