lifan 125-30 sprint overheating
ernstyle
PostPosted: 15:56 - 16 Jul 2009    Post subject: lifan 125-30 sprint overheating Reply with quote
hi hope some kind person out there can help me??? just bought a 2nd hand lifan 125-30 sprint and its overheating quite badly. also the bike keeps losing power when going up hill ( really struggles to get to 40mph )wondered if this was a common problem with these type of bikes?? any help would be very much appreciated thank you
stirlinggaz
PostPosted: 18:20 - 16 Jul 2009    Post subject: Reply with quote
hi,
those engines are known for running very hot.
not much you can do about it.
just fit a decent spark plug & change the oil often.
& make sure the air filter foam is clean.
you could try playing around with the mixture, if your confident.
cheers,
GAZ
baldy
PostPosted: 18:35 - 16 Jul 2009    Post subject: Reply with quote
Did you forget to turn the choke off?
ernstyle
PostPosted: 19:18 - 16 Jul 2009    Post subject: Reply with quote
whats the best plug to buy??? and no the choke is off
ernstyle
PostPosted: 19:19 - 16 Jul 2009    Post subject: Reply with quote
also just changed the oil
stirlinggaz
PostPosted: 19:29 - 16 Jul 2009    Post subject: Reply with quote
buy ngk or denso, or anything except the dodgy chinese ones that are fitted as standard( torch or lg usually).
spitfire123
PostPosted: 14:45 - 18 Jul 2009    Post subject: Reply with quote
does it have an oil cooller?
You won't be able to eat my dust......As it'll settle before you get there.
carlperkins00...
PostPosted: 20:33 - 18 Jul 2009    Post subject: Reply with quote
those chinese bikes have a reputation for running hot.. i had a lifan 125 dirtbike style thing... one day it got so hot it broke. Laughing
you could try different coolant, regular oil changes (as someone has said), spark plugs.
chances are it will happen for as long as you have the bike.
my advice is sell and buy something japanese.. chinese only gives you more problems.
if you hadnt already figured out.. i am launching a personal vendetta to rid the world of chinese bikes Twisted Evil Razz Laughing
do not hose the engine down!
i'm only saying it as once when i was a dumb little boy i hosed down an overheating engine on a quadbike... it broke.. Laughing
the whole thing pretty much welded into a big solid block. Razz
joan33987
PostPosted: 13:14 - 19 Jul 2009    Post subject: Reply with quote
hm... Somebody messed with the carburettor causing it to run lean? running lean will cause overheating
and will eventually "pre-ignition" and break the head gasket.
Maybe it's just how they work.
I don't know how you run it, but mine, if I do 30 minutes+ of motorway at 60mph, you could feel that the engine has less power when there's a slight up hill. If you stop at service station, the engine will die at idle. Let it rest for 5-10 minutes, it all comes back to normal again.
Yea, regular oil changes helps. Every 2000km, Semi-synthetic bike oil, such as the Silkolene Super 4 10w-40.
I'm based at Leeds, might be able to come and have a look at yours.
current toys: Skygo SG125-J 125cc stolen again 1992 Kawasaki GPZ500S (crashed damaged) 1996 Renault Clio 1.2 2005 CG125 project
The last post was made 17 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 59.82 Kb
