every think done that i can think of , any clues ? up date !
d-bug
PostPosted: 10:53 - 18 Jul 2009    Post subject: every think done that i can think of , any clues ? up date ! Reply with quote
rite i have had a few threads on here as i was goin though every think bit by bit , but as im at the end of trying to think what else it could be i have started a new thread so i can put it all in .
ok the bike is a cagiva mito 1994 mk2 i have just done a top end rebuild on the bike , i never rode the bike before , so i dont know how it was before .
im 250 miles into running it in , the bike still dont like to get passed 5000 revs its will if its pushed but it shouldnt be like that !
i will go along say in 3rd gear and i get to about 5 an half 1000 revs and it stops there for a little while and then will pass .
so far i have had the garage strip an clean the carb and set it back up , new spark plug an lead , new chain and sprockets , new air fliter well just the phome, it has a arrows race pipe and can , but the jets have not been done on the bike , yet !!!
does any 1 know what else i could look for on the bike to try an sort it !
cheers d-bug
Blue_SV650S
PostPosted: 12:11 - 18 Jul 2009    Post subject: Re: every think done that i can think of , any clues ? Reply with quote
d-bug wrote:
.... it has a arrows race pipe and can , but the jets have not been done on the bike , yet !!!.
Surely there is your problem right there?!?! Shocked
You have a race system on it and the stock jets, no wonder you have a massive flat spot ... you are actually prolly quite lucky it hasn't gone pop yet!! Neutral
d-bug
PostPosted: 12:40 - 18 Jul 2009    Post subject: Reply with quote
but wouldnt i have to ride the bike in 1st before having the jets done ?
Blue_SV650S
PostPosted: 12:46 - 18 Jul 2009    Post subject: Reply with quote
Absolutely not! ... I'd get whatever jets and needle jet setting arrow recommend in there ASAP! Shocked
d-bug
PostPosted: 14:17 - 18 Jul 2009    Post subject: Reply with quote
ok am on the case ! Confused
cheers d-bug
bladerunner
PostPosted: 19:00 - 18 Jul 2009    Post subject: Reply with quote
Apart from the jetting (does it do it at 1/4...1/2...3/4 and full throttle? as you could try lifting the needle a notch or 2 to see if it helps) The mito also came with 2 types of piston. a flat top and a dome top piston. are you sure you were given the correct one for the bike??? Seen that one done before!!! Shocked
d-bug
PostPosted: 06:23 - 20 Jul 2009    Post subject: Reply with quote
ok i have not really got any were since last time as it stands i have had the carb cleaned and set up in one garage and the power valve set up in a other garage as the 1st one wouldnt touch the PV Shocked
i have found that the bike will run when leaned out on the carb needle , and pass 6000 with ease but as it said i carnt have it running lean
what else could i look for as the other garage said they would rejet the bike but at mo im skint , and with it running fine when leaned out surley it carnt be that much to sort out ???????
cheers d-bug
The last post was made 17 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 57.36 Kb
