| d-bug |
 d-bug Renault 5 Driver
 Posted: 10:53 - 18 Jul 2009 Post subject: every think done that i can think of , any clues ? up date ! |
rite i have had a few threads on here as i was goin though every think bit by bit , but as im at the end of trying to think what else it could be i have started a new thread so i can put it all in .
ok the bike is a cagiva mito 1994 mk2 i have just done a top end rebuild on the bike , i never rode the bike before , so i dont know how it was before .
im 250 miles into running it in , the bike still dont like to get passed 5000 revs its will if its pushed but it shouldnt be like that !
i will go along say in 3rd gear and i get to about 5 an half 1000 revs and it stops there for a little while and then will pass .
so far i have had the garage strip an clean the carb and set it back up , new spark plug an lead , new chain and sprockets , new air fliter well just the phome, it has a arrows race pipe and can , but the jets have not been done on the bike , yet !!!
does any 1 know what else i could look for on the bike to try an sort it !
cheers d-bug
| Blue_SV650S |
| d-bug |
| Blue_SV650S |
| Blau Zedong |
 Blau Zedong Banned
| d-bug |
 Posted: 14:17 - 18 Jul 2009 Post subject: |
ok am on the case !
cheers d-bug |
| bladerunner |
 Posted: 19:00 - 18 Jul 2009 Post subject: |
Apart from the jetting (does it do it at 1/4...1/2...3/4 and full throttle? as you could try lifting the needle a notch or 2 to see if it helps) The mito also came with 2 types of piston. a flat top and a dome top piston. are you sure you were given the correct one for the bike??? Seen that one done before!!!  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| d-bug |
 Posted: 06:23 - 20 Jul 2009 Post subject: |
ok i have not really got any were since last time as it stands i have had the carb cleaned and set up in one garage and the power valve set up in a other garage as the 1st one wouldnt touch the PV
i have found that the bike will run when leaned out on the carb needle , and pass 6000 with ease but as it said i carnt have it running lean
what else could i look for as the other garage said they would rejet the bike but at mo im skint , and with it running fine when leaned out surley it carnt be that much to sort out ???????
cheers d-bug |
The last post was made 17 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
