Brake Drum Problems
Martay
PostPosted: 18:31 - 19 Jul 2009    Post subject: Brake Drum Problems Reply with quote
Hi,
I changed the tyre on my bike friday afterrnoon. Since then, the rear brake has been really ineffective and seems to be binding. (The rear drum is HOT to the touch after riding) So i loosened the adjusting nut by 1 1/2 turns, but this has made no difference. ( Rod operated drum brake)
Is there something basic i have overlooked?
Many thanks
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
metal ken
PostPosted: 18:33 - 19 Jul 2009    Post subject: Reply with quote
put it on the centre stand if you have one and adjust it off untill the wheel spins freely, make sure you still have brakes,
Cheers, Ken
My motorbike breakers metalken.co.uk
Current bikes, GSXR750 Fighter, GSXR7/12, RD350 race rep, KH400
Blue_SV650S
PostPosted: 18:37 - 19 Jul 2009    Post subject: Re: Brake Drum Problems Reply with quote
Martay wrote:
Hi,
Many thanks
When was the last time you greased up the splined activating spindle thingy? i.e. the bit that goes through the shoe holder hub needs reasonably frequent lubrication. When it runs dry, it has a tendency to make the rear brake stay on. If you press the rear brake peddle, then release to let everything spring back to the 'off' position, can you push the rear leaver arm on the hub back further by hand? if you can, then this is a sure sign that it needs a lube!! Thumbs Up
Martay
PostPosted: 21:21 - 19 Jul 2009    Post subject: Reply with quote
Many Thanks,
Il try both of these tommorow morning, its raining sideways out there at the minute!
Thanks for the help Smile
The last post was made 17 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 41.72 Kb
